RotorGear Pump
Old   January 24, 2005, 03:25
Default Hi, I would like to simula
Apurva Shukla (Shukla)
I would like to simulate gear pump using FOAMs automated mesh motion capability. Only thing I want to know is that can foam accomodate deforming meshes.
Thanks
Apurva
Old   January 24, 2005, 03:38
Default Yes. I have implemented an a
Hrvoje Jasak (Hjasak)
Yes. I have implemented an automatic mesh motion solver (that I am rather proud of), where you give it the prescribed boundary motion and it calculates the deformation of the mesh. The rest of the FVM already works with moving meshes. As for the solvers that use it, have a look at icoFoamAutoMotion.
You can also use topological changes (layer addition/removal, in your case), but that is more difficult.
Hrv
Old   January 24, 2005, 07:27
Default Currently OpenFOAM is not pro
Henry Weller (Henry)
Currently OpenFOAM is not properly setup to run rotating machinery problems (with the exception of the simple 2D mixer vessel tutorial) but there seems to be growing interest in having this functionality, paricularly MRF and rotating sliding interfaces in 3D. If we can find sponsorship for this work we will implement MRF and wrap the sliding interface functionality so make it easier to setup and run rotating machinery problems and provide a set of tutorial cases. But you must understand that this is a considerable amount of work and could not be undertaken without sponsorship.
Micro pump design / Diaphragm pump Michael Main CFD Forum 2 March 1, 2013 01:56
Centrifugal Pump 2D and 3D Glen FLUENT 1 February 18, 2010 01:18
pump yang CFX 0 May 28, 2002 10:00
CFD-3D Pump Jack Keays FLUENT 5 October 24, 2000 06:07
cfd pump. Jack Keays FLUENT 0 May 2, 2000 08:46
