Home > Forums > OpenFOAM Running, Solving & CFD
Steady calculation
Old   January 5, 2005, 10:29
Default Hi: I am a new user of OpenF
S.H.Yang (Yang)
Hi:
I am a new user of OpenFoam,I have some questions about OpenFoam:
1)when I run sonicFoam/forwardstep case,I change the initial internal U field from (0,0,0) to (3,0,0),why the calculation became divergence?
2)I want a calculation with sonicTurbFoam to keep the CoNum constant instand of DeltaT constant ,how can I do this?
Old   January 5, 2005, 14:54
Default Hi, I did 2) in the follow
Luiz Eduardo Bittencourt Sampaio (Sampaio)
I did 2) in the following way:
added the following line to the code after calculating CoNumber (# include CourantNo.H)
alfat = CFL/CoNum;
runTime.setDeltaT(alfat*runTime.deltaT().value());
Obviously, alfat had been previously defined as scalar and CFL was read from a file (defined as float).
Cheers,
Luiz
Old   January 6, 2005, 03:42
Default Sampaio Thanks for your help
S.H.Yang (Yang)
Sampaio
Thanks for your help.It works fine.
Old   January 11, 2005, 10:28
Default You should be aware that Open
Eugene de Villiers (Eugene)
You should be aware that OpenFOAM already has a mechanism for maintaining a steady maximum CFL number.
See the dambreak tutorial and interFoam solver for details.
Eugene
Thread Tools
Trackbacks are On
Damp turbulent behaviour for a steady state calculation andimb OpenFOAM Running, Solving & CFD 0 May 4, 2006 05:39
Steady LES? GER Main CFD Forum 3 May 12, 2005 14:37
Steady RANS calculation Rasmus Gjesing (Gjesing) OpenFOAM Running, Solving & CFD 1 February 8, 2005 10:55
Steady/Unsteady Pravesh Kumar FLUENT 11 September 18, 2003 00:21
BFS: steady? Jan Ramboer Main CFD Forum 1 September 9, 1999 14:04
