Dear Sirs,
My simulation was
Dear Sirs,
My simulation was going ok (Co number, residuals, etc...) and suddenly, it stoped, accusing the following error. Do you know what caused it? Thank you very much, Luiz ... time step continuity errors : sum local = 3.11323e-12, global = -4.49462e-13, cumulative = -1.76166e-11 --> FOAM FATAL IO ERROR : IOstream::check(const char* operation) : error in IOstream "/home/luizebs/foam/foam2.2/tutorials/oodles/flatplate2/0.07727/Bmean" for operation Ostream& operator FOAM Warning : dictionary::add(entry* ePtr) : attempt to add an entry already in dictionary "" --> FOAM Warning : dictionary::add(entry* ePtr) : attempt to add an entry already in dictionary "" --> FOAM FATAL IO ERROR : IOstream::check(const char* operation) : error in IOstream "/home/luizebs/foam/foam2.2/tutorials/oodles/flatplate2/0.07727/Bmean" for operation Ostream& operator<<(Ostream&, const scalar&)IOstream::check(const char* operation) : error in IOstream "/home/luizebs/foam/jobControl/finishedJobs/blackmagic.9663" for operation Ostream& operator<<(Ostream&, const string&) file: /home/luizebs/foam/jobControl/finishedJobs/blackmagic.9663 at line 1. Function: IOstream::check(const char* operation) const in file: db/IOstreams/IOstreams/IOcheck.C at line: 47. FOAM exiting |
There seem to be two messages
There seem to be two messages:
- Foam trying to write Bmean for time 0.07727 and failing for some reason and -Foam trying to log the error message to the finishedJobs dictionary and failing because the entry already was in the dictionary. I have no idea why the write of the field failed. Is there enough diskspace? Is the directory write protected? Is there already a Bmean field in the directory? Is another process trying to write the same file? |
Sorry, I did not realized my
Sorry, I did not realized my writeinterval was set to one and I run out of disk space. Silly mistake.
Thank you, Luiz |
