Vertex Based Motion
Old   March 19, 2009, 02:18
Default Vertex Based Motion
John Wang
cwang5 is on a distinguished road
Hi, I'm trying to simulate a moving rigid "tail" behind a block, and while searching in the forum came across the term "vertex based motion", but could not find anything else. My question is that if it is the correct direction to look into, and if so, if it is implemented in OF-1.5 and if there is any documentation and/or tutorials for such setup? Thanks for the help.
John
cwang5 is offline   Reply With Quote
Old   March 19, 2009, 04:43
Etienne Lorriaux
elorriaux is on a distinguished road
i've not found examples or doc about vertex based motion solvers. Try to search 'pointDisplacement', 'displacementLaplacian', 'displacementSBRStress' and you will find a few tips on how to use those motion solvers.
Be careful that the displacement is relative to the original mesh and not the previous time step.
Sincerely, Etienne.
elorriaux is offline   Reply With Quote
Old   March 20, 2009, 01:17
John Wang
Hi Etienne,
Thanks for the reply. I tried searching for the terms you mentioned, but the forum returned nothing when searching for the last two. For the pointDisplacement, is it sufficient to simply modify the dynMeshDict and pointMotionU, or do I have to modify the solver? Thanks.
Diff b/w node based & cell based methd Murthy FLUENT 0 April 2, 2008 13:18
Solver in version 4, cell or vertex based Marcin Siemens 0 April 26, 2007 20:56
which is better? vertex based or cell centered? neil Main CFD Forum 1 April 23, 2007 16:54
Basic Vertex-Based Finite Volume Soheyl Main CFD Forum 2 March 26, 2005 10:03
Cell Vertex Based FVM A. S. Main CFD Forum 1 January 28, 2002 07:46
