MRFSimpleFoam and BCs
Old   November 19, 2012, 05:55
Default MRFSimpleFoam and BCs
flowing is on a distinguished road
Dear all,
I have some questions regarding a simple case for MRFSimpleFoam.
I have a cylindrical domain in which one side is inlet, the other is outlet and in it there is a small fan that is rotating.
Ideally, I want to let the fan determine the input flowfield.
For this problem I used laminar flow which I plan to change it to turbulent when the inlet velocity is determined.
I tried to use the following boundary conditions:
Inlet
U: zeroGradient
p: zeroGradient
Outlet
U: zeroGradient
p: fixedValue
Walls
U: fixedValue 0
p: zeroGradient
With the above settings I cannot get convergence and in the flow field there are backflows happening in various areas of the domain, which seems logical due to U zeroGradient at inlet and outlet.
I also tried to use pressureInletVelocity for U at the inlet but the results were worse.
If I impose U: fixedValue at the inlet, then everything works and I get convergence quite quickly.
Any ideas on this?
flowing is offline   Reply With Quote
Old   November 19, 2012, 06:30
zaynah K.
zaynah04 is on a distinguished road
hi
have you been able to solve that?
zaynah04 is offline   Reply With Quote
Old   November 19, 2012, 08:34
I was able to solve the problem only when I had defined an inlet velocity.
I have not been able to solve the case if I want the fan to determine the inflow.
Old   November 19, 2012, 09:21
zaynah K.
hi can you please explain to me how you had defined the inlet vel?
thnaks
zaynah
Old   November 19, 2012, 11:04
for the case that worked you can either define e.g.
inlet
type fixedValue;
value uniform (1 0 0);
or
inlet
type surfaceNormalFixedValue;
refValue uniform -1;
both of the above work.
Old   November 19, 2012, 11:06
zaynah K.
the (1 0 0)
1 define 1m/s in x drection right?
but what does the
means?
Old   November 19, 2012, 11:14
B
Heroic is on a distinguished road
Originally Posted by zaynah04 View Post
the (1 0 0)
but what does the means?
surfaceNormalFixedValue uses the outward normal vector (the vector normal to your inlet, pointing outside of the domain). If you give it a value of -1, it should give you a velocity of 1 m/s into your cylindrical domain.
Heroic is offline   Reply With Quote
Old   November 19, 2012, 22:21
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Pretty easy to let the fan determine the inflow.
U
    inlet
       type     pressureInletVelocity;
       phi      phi;
       value    uniform (0 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
p
    inlet
        type            totalPressure;
        p0              uniform 0;
        phi             phi;
        U               U;
        rho             none;
        psi             none;
        gamma           1.0;
    outlet
        type            fixedValue;
        value           $internalField;
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   November 21, 2012, 08:05
Linnemann thank you very much.
totalPressure and pressureInletVelocity worked very well.
Maybe I could have realized it after studying a little more the manual.
From what I understand, totalPressure BC is linked with pressureInletVelocity, pressureInletOutletVelocity, etc conditions or the opposite?
Old   November 22, 2012, 14:09
Aathavan
Aadhavan is on a distinguished road
Hi Linnemann,
The explained boundary conditions are fine, but i have small doubt.
how to define are where to define the quantity of the flow.
If i want to define 5 m3/s. how to define this with the above given example BC.
Thanks,
Aadhavan
Aadhavan is offline   Reply With Quote
Old   November 22, 2012, 20:57
linnemann's Avatar
Niels Nielsen
Hi
With the above BC's you cant define the volume flow.
Then you switch to the below BC's
U
    inlet
        type              flowRateInletVelocity;
        flowRate  constant 0.5; // m3/s for incompressible and kg/s for compressible
    outlet
        type            zeroGradient;
p
    inlet
        type        zeroGradient;
    outlet
        type            fixedValue;
Linnemann
Old   November 23, 2012, 02:03
Aathavan
Hi Linnemann,
Thanks for your reply, This BC already i am using.
I want to use pressureInletVelocity BC, if I use this, how can I understand that, at what flow rate it is the simulation is going on.
in my case the fan is designed for 5m3/s, if I want to see the performance at different flowRate, can I use this BC (pressureInletVelocity), if so how can I implement it.
thanks,
Aadhavan
Old   November 26, 2012, 09:30
Post
  #13
k zhang
skykzhang is on a distinguished road
Originally Posted by linnemann View Post
Hi
U
    inlet
    outlet
        type            zeroGradient;
p
    inlet
        type        zeroGradient;
    outlet
        type            fixedValue;
Hi Linnemann,
i have some doubts with the U value of inlet. if write it like :
type fixedValue;
value uniform (0.5 0 0);
OK?
if i have a model like this: inlet U=0.5, outlet contact the atmosphere. the fluid flow from the inlet to the outlet.
Attacted are the Pd and U , run the interFoam, wrong... can you give me some advises?P.jpg
skykzhang is offline   Reply With Quote
bcs, boundary conditions, mrfsimplefoam
Suggestions on Mesh and Schemes for MRFSimpleFoam mixer OpenFOAM Running, Solving & CFD 3 September 1, 2009 10:50
