Orifice plate using rasInterFoam
Old   March 19, 2009, 04:41
Default Orifice plate using rasInterFoam
Gareth
gareth__it_power is on a distinguished road
I'm trying to validate a simple orifice plate model for use in a larger assembly, but it is not behaving as I would expect. As you can see below the 'tail' from the orifice adheres to one side of the duct, rather than remaining symmetrical. Is this expected? Duct is 25mm wide, air, inlet velocity = 0.5m/s.
gareth__it_power is offline   Reply With Quote
Old   March 20, 2009, 15:31
Kevin Smith
kev4573 is on a distinguished road
This might be the Coanda effect at work, where a jet attaches itself to a boundary. There are papers out there that describe this phenomena.
kev4573 is offline   Reply With Quote
Old   March 22, 2009, 08:26
Kerstin Heinen
kerstin is on a distinguished road
Is this result from steady state simulation?
Maybe transient run shows fluctuation of this tail up and down?
I would guess, that's not impossible for this kind of flow to show such a behaviour.
Kerstin
kerstin is offline   Reply With Quote
Old   June 20, 2012, 09:41
Bernhard Linseisen
Linse is on a distinguished road
Long time ago this has been. But I am experiencing something similar at the moment. The strange thing is: While using an incompressible solver, everything looks fine and qualitatively similar to ISO 5167-2 results.
But if I use rhoSimpleFoam instead of simpleFoam I get kind of two layers, one behaving normally in the outer half of the flow and something close to a jet in the middle half of the flow...
Any ideas concerning that?
Could you maybe tell which solver you used at that time, if it was compressible or incompressible, if you solved the "problem" or accepted the flow to be different from what one would have expected?
Linse is offline   Reply With Quote
Cavitation in orifice plate Juan Catelén CFX 2 March 29, 2007 14:46
Cavitation of an Orifice Plate in Pipe System CFXuser CFX 0 April 8, 2006 09:30
ORIFICE PLATE, PULSATILE REIS CFX 1 July 20, 2005 13:28
Parallel Plate Rheometer vs Cone & Plate beginner Main CFD Forum 0 March 19, 2003 11:49
Orifice plate flow Kyle Kisebach Main CFD Forum 2 June 8, 2001 09:55
