Piston motion with time varying experimental data oscillatingFixedValue |
March 12, 2009, 17:33 |
I am using openfoam 1.4 in cyg
Sean Bian
Rep Power: 17 |
I am using openfoam 1.4 in cygwin to solve internal compressible turbulent flow under the motion of a piston. By modifying rhoTurbFoam I can use oscillatingFixedValue in cellMotionUX to define a sinusoidal piston motion Ux = f*(a*sin(2*pi*t)+1). The mesh deforms as expected and the simulation looks reasonable.
Now I want to drive the piston with motions (time varying, no sinusoidal displacement) measured from experiment. How can I do it? |
March 13, 2009, 02:07 |
if I remember rightly,
Marco Müller
Rep Power: 17 |
if I remember rightly, this is not trivial. Maybe you can approximate the values analytically and use groovyBC. I tried just yesterday to apply the "standard piston law of motion" (way over time) and it worked perfect. Best Regards Marco |
March 13, 2009, 15:18 |
Can I just modify the code to
Sean Bian
Rep Power: 17 |
Can I just modify the code to read and interpolate the external velocity at where Ux = f*(a*sin(2*pi*t)+1) is executed?
March 19, 2009, 10:06 |
Sean Bian
Rep Power: 17 |
dang... it's readily there! just modify cellMotionUx (or other initial files) like:
piston { // type oscillatingFixedValue; // refValue uniform 1.; // amplitude .2; // frequency .5; // value uniform 0; type timeVaryingUniformFixedValue; timeDataFileName "pistonVelocity.dat"; value uniform 0; } |
CFX Piston Motion (CEL) | Dante | CFX | 4 | May 28, 2012 06:08 |
Piston motion with time varying experimental data oscillatingFixedValue | eno | OpenFOAM Running, Solving & CFD | 0 | March 12, 2009 17:31 |
motion of piston wave maker | chandra sekhar b | Main CFD Forum | 0 | October 31, 2008 07:06 |
Piston Motion | A Student | Siemens | 0 | April 18, 2006 11:36 |
piston motion | Arpan | Siemens | 1 | March 9, 2006 07:52 |
