Home > Forums > OpenFOAM Running, Solving & CFD
How to show the steps/iterations
Old   March 25, 2009, 12:55
Default How to show the steps/iterations
Sebastian
fightingfalcon23 is on a distinguished road
Hi every one,
it's a quite short questions: I am working with OpenFoam and pyFoam. How can i see the number of actual iterations. In the shell and the PyFoam-plots I can only see the time, not the steps or the iterations. In the other threads i found a lot of plot with the iterations/steps on the x-axis.
A lot of words for a short questions
Greatings
Sebastian
fightingfalcon23 is offline   Reply With Quote
Old   March 26, 2009, 05:43
Assistant Moderator
Bernhard Gschaider
A short answer for a short question: Almost all PyFoam-Utilities have a --help-option. That will answer your question. And if the --with-xx-options are not sufficient for you you can always define custom-plots using --custom or --regexp
Old   April 15, 2009, 09:56
Sebastian
Thanks gschaider (bavarian?) and sorry for the late answer.
I used the help-function of pyfoam and it's possible to plot the iterations of the timesteps. But i want to plot for example the residuals in a graph which shows the iterations an the x-axis and not the the time.
So at the and i want to see a graph, that shows the complete number of iterations ( for example 10000) and the gradient of the residuals.
Old   April 15, 2009, 13:28
Assistant Moderator
Bernhard Gschaider
Hi!
No. Not Bavarian. Austrian. Language is similar, but WE cheered for Barcelona this week. SCNR
You mean you want the accumulated number of iterations as the x-axis? So if for instance simpleFoam gives these iterations for p (the other question is of course: iterations of which solver)
Time = 1 , Initial residual = 1, Iterations = 12
Time = 2 , Initial residual = 0.8, Iterations = 13
Time = 3 , Initial residual = 0.69, Iterations = 10
Time = 4 , Initial residual = 0.53, Iterations = 9
The you want to plot this data:
it = 0 , res = 1
it = 12, res = 0.8
it = 25, res = 0.69
it = 35, res = 0.53
(Residual as a function of the total amount of iterations).
No. Sorry. pyFoam can't do that. The best guess would be to use the --write option an then read (using excel, Perl, Python, origin, ....whatever) the resulting data files and do the calculation with that tool
Bernhard
PS: Maybe s subclass of the LogLineAnalyzer-class could also do the trick, but that is more work
Old   April 15, 2009, 14:42
Sebastian
Thanks again! I'm from Munich, but cheered for Barcelona, too .
Back to topic:
I found some pictures, where you can see , what i am looking for. For example in this thread:
Strange Velocity in impeller of MRFSimpleFOAM
There you can see the following image. Does anybody know, how to create such graphs?
CU
fightingfalcon
Old   April 16, 2009, 08:59
Assistant Moderator
Bernhard Gschaider
Ah. 1860
Back to topic:
Right. Sorry to all those not from the area
CU
fightingfalcon
Again: on the x-axis: Are these iterations of the solver? Then this is what the usual residuals-graph is displaying anyway (it's just called Time and the scaling is different - but logarithmic)
If you want iterations of a(!) linear solver on the x-axis then you'll have to go with the advice from above
Or did I completely miss the point?
Bernhard
Old   April 17, 2009, 04:25
Sebastian
I think you're right, but I am too new to CFD and OpenFoam! So thank you for your patience!
Is there a difference between steady-state simulation and simulation over a certain time? I'm using rhoTurbFoam for an unsteady case. So I see the Time on the X-axis like shown on the picture. I hope, I'm begining to understand.
Thanks a lot
Sebastian
Old   April 17, 2009, 04:26
Sebastian
Oh.... here's the picture:
Old   April 19, 2009, 01:41
Gijsbert Wierink
gwierink is on a distinguished road
Hi Sebastian,
Yes, there is a difference between steady-state and transient cases. The steady-state case tries to solve for a steady-state solution of the system, i.e. what it would look like after a long time of running. The transient, or time dependent, case solves for actual time, so you can see the time evolution of the system you're dealing with. That is why the steady-state case shows iteration steps (iterations toward steady-state) and the transient case shows actual time steps of the system (although every time step is also iterated of course ). Or is this not what you meant to ask?
Regards,
Gijs
gwierink is offline   Reply With Quote
Old   April 30, 2009, 09:09
Wolfgang Heydlauff
wolle1982 is on a distinguished road
To plot the residuals on-the-fly on screen graphically, I wrote a short tutorial.
See thread Tutorial of how to plot residuals !
wolle1982 is offline   Reply With Quote
Thread Tools
Trackbacks are On
How to show part of the geometry. gab FLUENT 1 September 15, 2007 20:16
Defined Variable does not show Meri CFX 3 August 30, 2004 10:16
cannot show the contour pic arwang FLUENT 2 May 10, 2004 09:45
Show time per iteration Rogier van Nalta FLUENT 2 April 20, 2004 11:39
In a swirl flow, how to show tangetial velocity Wang FLUENT 1 October 27, 2000 03:59
