RhoSimpleFoam
Like Tree1Likes
  • 1 Post By mkraposhin
Old   February 9, 2009, 15:11
Default Hi. I'm just wondering if anyo
John Paul Handrigan
jphandrigan is on a distinguished road
Hi. I'm just wondering if anyone can tell me what this error means. Thanks in advance.
Here's the print-out I get when I run the solver:
[actmodel@r4-bcc-a010590 rhoSimpleFoam]$ rhoSimpleFoam
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
Exec : rhoSimpleFoam
Date : Feb 09 2009
Time : 15:09:20
PID : 20392
Case : /mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/junk-1.5/run/rhoSimpleFoam
nProcs : 1
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package hThermo<puremixture<sutherlandtransport<speciether mo<hconstthermo<perfectgas>>>> >
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
#0 Foam::error::printStack(Foam:stream&) in "/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFOAM-1.5/lib/linux64Gc cDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFOAM-1.5/lib/linux64Gc cDPOpt/libOpenFOAM.so"
#2 __restore_rt in "/lib64/tls/libc.so.6"
#3 Foam::compressible::RASModels::kEpsilon::kEpsilon( Foam::GeometricField<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFOAM-1.5/lib/linux64Gc cDPOpt/libcompressibleRASModels.so"
#4 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<foam::compressible ::rasmodels::kepsilon>::New(Foam::GeometricField<d ouble,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFOAM-1.5/lib/linux64Gc cDPOpt/libcompressibleRASModels.so"
#5 Foam::compressible::RASModel::New(Foam::GeometricF ield<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFOAM-1.5/lib/linux64Gc cDPOpt/libcompressibleRASModels.so"
#6 main in "/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFOAM-1.5/applications/ bin/linux64GccDPOpt/rhoSimpleFoam"
#7 __libc_start_main in "/lib64/tls/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/mnt/hypatia/linux_home/rhel4_home/actmodel/OpenFOAM/OpenFOAM-1.5/applications/ bin/linux64GccDPOpt/rhoSimpleFoam"
Floating exception
jphandrigan is offline   Reply With Quote
Old   February 10, 2009, 02:49
Default Hi John, With a floating po
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Hi John,
With a floating point exception at the very beginning, check that your fields are initialized to something sensible. Eg, don't use zero for the tke.
olesen is offline   Reply With Quote
Old   February 10, 2009, 04:55
Default Also check that (absolute) pre
Ville Tossavainen
villet is on a distinguished road
Also check that (absolute) pressure isn't zero anywhere in the field. Same thing with temperature (in Kelvins).
villet is offline   Reply With Quote
Old   February 10, 2009, 06:25
Default Thanks. I'll give it a try thi
John Paul Handrigan
Thanks. I'll give it a try this morning, and let you know how it turns up.
Old   February 18, 2009, 04:14
Default Hi, maybe anyone knows this e
Steven Darkes
stevendarkes is on a distinguished road
maybe anyone knows this error as well. Thanks in advance!
Here's the print-out I get when I run the rhoSimpleFoam solver:
Time = 6
smoothSolver: Solving for Ux, Initial residual = 0.300191, Final residual = 0.0129647, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.0539535, Final residual = 0.00221057, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.996496, Final residual = 0.0279006, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0954665, Final residual = 0.00199884, No Iterations 1
Maximum number of iterations exceeded#0 Foam::error::printStack(Foam:stream&) in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libbasicThermophysicalMode ls.so"
#3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::correct() in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libbasicThermophysicalMode ls.so"
#4 main in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam "
#5 __libc_start_main in "/lib/libc.so.6"
#6 Foam::regIOobject::readIfModified() in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam "
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/specie/lnInclude/ specieThermoI.H at line 78.
FOAM aborting
stevendarkes is offline   Reply With Quote
Old   February 18, 2009, 09:22
Default It means, that you've got nega
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
It means, that you've got negative temperature
Gerhard likes this.
mkraposhin is offline   Reply With Quote
Old   February 18, 2009, 10:02
Default That's it! Thank's a lot!!
Steven Darkes
Maybe I should change my viscosity. E.g. define it as a function of the Temperature.
What I didn't understand up to now in the thermoPhysicalProperties is the heat fusion Hf. How can I get this value?
Old   February 19, 2009, 03:16
Default I think, you must look for in
mkraposhin's Avatar
Matvey Kraposhin
I think, you must look for in special literature
Old   February 19, 2009, 05:21
Default Now I got positive temperature
Steven Darkes
Now I got positive temperatures, but anyway the solver aborts after a couple of iterations, probably because of division by zero!
Maybe you know what the reason could be?
Here the error message and below my thermoPhysicalProperties, because I think the problem is coming from there.
Time = 7
smoothSolver: Solving for Ux, Initial residual = 0.999964, Final residual = 0.0151332, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.999954, Final residual = 0.03379, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.655577, Final residual = 0.0122258, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.598926, Final residual = 0.026901, No Iterations 1
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xffffe420]
#3 Foam::hThermo<foam::puremixture<foam::sutherlandtr ansport<foam::speciethermo<foa m::hconstthermo<foam::perfectgas> > > > >::calculate() in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libbasicThermophysicalMode ls.so"
#4 Foam::hThermo<foam::puremixture<foam::sutherlandtr ansport<foam::speciethermo<foa m::hconstthermo<foam::perfectgas> > > > >::correct() in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libbasicThermophysicalMode ls.so"
#5 main in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam "
#6 __libc_start_main in "/lib/libc.so.6"
#7 Foam::regIOobject::readIfModified() in "/home/sda2sh/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/rhoSimpleFoam "
Gleitkomma-Ausnahme
thermoType hThermo<puremixture<sutherlandtransport<speciether mo<hconstthermo<perfectgas>>>> >;
mixture
argon 1 39.948 // specieThermo
520 0 // hConstTherm
1.96566e-06 144.4 // transportCoeffs/sutherlandTransport (Star-CD)
Old   February 19, 2009, 07:06
Default The error in converting h-valu
mkraposhin's Avatar
Matvey Kraposhin
The error in converting h-values to T. Can you post description of your case?
Old   February 19, 2009, 09:01
Default I sent it to you by mail!
  #11
Steven Darkes
Old   March 3, 2009, 11:14
Default I don't know why, but I cannot
  #12
Steven Darkes
I don't know why, but I cannot get a converging result for this geometry using the left edge as symmetry axis and consequently the front and back surface as wedge boundary!
Do you think this problem could be resolved by a full 360 degree geometry?
Old   March 3, 2009, 11:20
Default http://www.cfd-online.com/Open
  #13
Steven Darkes
Old   March 3, 2009, 11:25
  #14
Steven Darkes
Old   March 3, 2009, 12:56
  #15
Steven Darkes
Old   March 3, 2009, 13:19
Default hi, Steven! 1) i can"t see
  #16
mkraposhin's Avatar
Matvey Kraposhin
hi, Steven!
1) i can"t see your images
2) why you want to use 'wedge' patch? maybe you must try symmetryPlane for front and back surfaces.
Old   March 4, 2009, 11:04
Default Hi Matvej, thank's a lot fo
  #17
Steven Darkes
Hi Matvej,
thank's a lot for your manipulation of my files. they worked fine, but as soon as I put wedge boundaries it doesn't converge any more.
Even symmetryPlanes cause the same problem!
Old   March 27, 2009, 09:44
Ehsan
ehsan is on a distinguished road
Hi Steven Darkes,
I am facing the same your problem hthermo before. So did you have a solution for this? If so please let me know. Thanks
ehsan is offline   Reply With Quote
Old   March 29, 2009, 11:05
mkraposhin's Avatar
Matvey Kraposhin
Hi, Hung Nguyen
after some experience with rhoSimpleFoam (or rhoTurbFoam), i found, that all errors, that arises when converting h-values to T-values means an improper case setup (pressure boundaries, turbulence initial setup, physical BC, etc). Can you tell more about your case?
BC for rhoSimpleFoam uli_u OpenFOAM Running, Solving & CFD 77 April 4, 2013 11:28
RhoSimpleFoam maritozzo OpenFOAM Running, Solving & CFD 1 April 30, 2010 18:18
RhoPorousSimpleFoam RhoSimpleFoam spv24 OpenFOAM Running, Solving & CFD 4 November 12, 2008 09:19
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
RhoSimpleFoam luca OpenFOAM Running, Solving & CFD 0 August 22, 2005 12:26
