rotating wall inside of an MRF zone - fixedValue or movingWallvelocity?
Like Tree2Likes
  • 1 Post By evrikon
  • 1 Post By evrikon
Old   March 26, 2009, 05:29
Default rotating wall inside of an MRF zone - fixedValue or movingWallvelocity?
Oleksiy Kurenkov
evrikon is on a distinguished road
Send a message via Skype™ to evrikon
Hello together,
I simulate a simple axial fan with MRFSimpleFoam. Everithing works fine, however, I have got very low pressure jump predicted. I' looking now where mistake in my settings is.
The question is what the type of boundary condition I should use for the rotor. Rotor in my simulation is a rotating fan wall inside of the MRF zone and rotates of course with the same angular velocity as the whole MRF zone. If I would use fixedvalue; uniform (0 0 0) like in the tutorial mixerVessel2D, does it stay at rest? Should I take movingWallVelocity instead (s. below)?
From my ../0/U;
boundaryField
STATOR
type fixedValue;
value uniform (0 0 0);
ROTOR
type movingWallVelocity;
Other question for my full understanding: does MRF model in OF use an absolute velocity formulation or relative velocity formulation? "absolute" means it solves the equations still in non-rotating coordinate system, relative I mean as rotating coordinate system. This question refers to the problem I encountered, namely with absolute velocity formulation the wall should rotate, with relative should stay at rest relatively to the rotating zone where it is located in.
Alex
jiaojiao likes this.
evrikon is offline   Reply With Quote
Old   April 17, 2009, 08:21
Default Resolved
Oleksiy Kurenkov
In the meantime I tried itself, read through the forum etc. If the case set up correctly fixed value condition for a wall inside of a rotating zone leads to correct radial velocity distribution on this wall. One can see it in paraview.
_Chris_ likes this.
Old   November 28, 2013, 14:02
nash is on a distinguished road
hi evrikon,
sorry for bringing this old thread up.
do you manage to get the right pressure rise?
i simulate the radial fan now, and i got lower value of pressure rise. and the residuals of velocity fall only to 3rd order of magnitude.
for this simulation, i use approach of mrf and turbulence model laundersharma and komegasst (low re model implementation).
any suggestion for better result?
nash is offline   Reply With Quote
Old   April 30, 2015, 03:51
M. Montero
be_inspired is on a distinguished road
Quick question.
Did you make any faceZone? It is to know if boundary faces are selected or not ( including wall faces)
be_inspired is offline   Reply With Quote
[blockMesh] StitchMesh on two patches anita OpenFOAM Meshing & Mesh Conversion 31 April 4, 2013 11:51
Segmentation Fault in fluent3DMeshToFoam cwang5 OpenFOAM Bugs 23 April 13, 2011 15:37
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
