Rotating cylinder with GGI
Hi everyone !
I am a new user of OpenFOAM 1.5-dev. I would like to study a VAWT (Vertical Axis Wind Turbine). But first, I get trained by analysing the flow around a cylinder. I do step by step: I simulated laminar flows over a fixed 2D cylinder, then turbulent ones, then laminar flows over a 2D rotating cylinder using GGI. Later on, I'll use a more complex geometry 2D and 3D. My question is how to solve a turbulent flow over a 2D rotating cylinder using GGI ? There is no tutorial on it, and I don't really know how to change the applicationClass in system/controlDict. In the example mixerGgi, it is "icoTopoFoam", but what should it be for a turbulent flow ? I remind you I am a very new Foamer, so feel free to give details, tips, advices, links and even example cases that you have done. I thank you in advance. Yours, Laurent |
Hi!
Is my question not clear ? Is it stupid or illogical ? I don't think I am the only one who tries to simulate turbulent flows with a dynamic mesh (GGI)... Am I ? By the way, in system/controlDict, what is the difference between "application" and "applicationClass" ? Laurent |
I'm attempting to use turbDyMFoam, but haven't actually figured it all out yet.
I would like you to read the following Wiki page: http://openfoamwiki.net/index.php/Si...vaned_diffuser You should be able to find a lot of useful information there. Håkan. |
