-   -   buoyantSimpleFoam Message error (http://www.cfd-online.com/Forums/openfoam-solving/63502-buoyantsimplefoam-message-error.html)
Khelian973 April 10, 2009 03:52
Hello Foamers,
Im a beginner. I use OpenFoam 1.5 on Ubunto...
I would like to use the solver buoyantSimpleFoam for a case, so I started the tutorial. But i have this error message when i launch the solver
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading thermophysical properties
Selecting thermodynamics package hThermo<pureMixture<constTransport<specieThermo<hC onstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0.85;
alphah 1;
alphak 1;
alphaEps 0.76923;
Calculating field g.h
Creating field pd
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 4.95158e-06, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 7.32619e-06, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 4.95158e-06, No Iterations 3
#0 Foam::error::printStack(Foam::Ostream&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#6 main in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#7 __libc_start_main in "/lib/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
Floating point exception
I think it's probably due to the installation of the librairies, but im not really into it, so i would like to have a confirmation and the solution to solve the problem..
Thanks
hellorishi April 15, 2009 03:40
foamInstallationTest
maybe you can post the output of foamInstallationTest
if this is working without errors, try running icoFoam tutorial first. I also had problems with buoyantSimpleFoam and then I shifted to OF-1.5.x
Khelian973 April 15, 2009 04:24
Hello Rishi
First, thanks for your answer...
I started by icoFoam, without any problems. I've tried severals tutorials solvers (icoFoam, turbFoam, buoyantFoam) and they worked but not buoyantSimpleFoam. And it is precisely the solver i need for my study:(
Here you are the results of my installation test. There are 2 No, but i dont know what it means ...
Checking basic setup...
Shell: bash
Host: foamix
OS: Linux version 2.6.27-11-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /DATA/Softs/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/openfoam/OpenFOAM/openfoam-1.5 yes no
$WM_THIRD_PARTY_DIR /DATA/Softs/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /DATA/Softs/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR /DATA/Softs/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...OAM/openfoam-1.5/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.1 ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam 1.5 .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam
Checking networking...
Action Result Crit
Pinging_foamix Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
Critical systems ok.
hellorishi April 15, 2009 06:28
a guess: possibly epsilon is initialised to ZERO in 0 directory. Epsilon has to be non-zero.
try running the buoyantSimpleFoam with turbulence turned OFF and see if it runs.
Khelian973 April 15, 2009 08:01
Epsilon wasnt to ZERO and with the turbulence off, i have the same message...i double checked all my files to see a mistake but i dont find one...
is it possible to send you the case, and you try to run it for me ?... if it works on your computer, i will know that it's from my installation (if you have time of course)
thanks for helping me
hellorishi April 15, 2009 10:45
Hi Kyian
I saw your case. The problem is that the tutorial has one small error. P is initialised to 0.
Changing "p" file
internalField Uniform 10000;
solves the problem
hope this solves your problem.
regards
Rishi
Khelian973 April 16, 2009 04:57
hi, Thanks Rishi
the tutorial runs perfectly
Khelian973 May 25, 2009 04:07
Hi Foamers,
After the tutorials on buoyantSimpleFoam i've tried to run a simple case, already use in another solver (simpleFoam), but adding temperature in the flow.
This time the solver stops after reading the thermophysical properties. I dont understand how it's possible. I created the case copying the tutorial case of buoyantSimpleFoam.
If you have any suggestions...
Thansk in advance
Kyian
Here is the message i have
Create time
#3 Foam::hThermo<Foam::pureMixture<Foam::constTranspo rt<Foam::specieThermo<Foam::hConstThermo<Foam::per fectGas> > > > >::calculate() in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 Foam::hThermo<Foam::pureMixture<Foam::constTranspo rt<Foam::specieThermo<Foam::hConstThermo<Foam::per fectGas> > > > >::hThermo(Foam::fvMesh const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#5 Foam::basicThermo::addfvMeshConstructorToTable<Foa m::hThermo<Foam::pureMixture<Foam::constTransport< Foam::specieThermo<Foam::hConstThermo<Foam::perfec tGas> > > > > >::New(Foam::fvMesh const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#6 Foam::basicThermo::New(Foam::fvMesh const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#7 main in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#8 __libc_start_main in "/lib/libc.so.6"
#9 Foam::regIOobject::readIfModified() in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
Rachel June 2, 2009 13:26
One possible problem between different solvers is the use of Pressure units.
Kindly check the pressure units in both solver. It might be a cause of problem. Not sure.
