movingConeTopo tutorial from 1.5-dev crashes with Floating Point Exception
Dear Forum Users and Developers
Good Evening. I tried the movingConeTopo tutorial as given in dev version. (pulled out on 21st April 2009). and it crashes with the floating point exception. The debug info shows the following: Stack trace: #0 0x000000000043c38c in Foam::divideEqOp2<double, double>:: operator() (this=0x7fff08391cf0, x=@0x7b0b10, y=@0x7fff08391d00) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/ops.H:75 #1 0x000000000043de97 in VectorSpaceOps<3, 0>::eqOpS<Foam::VectorSpace<Foam::Vector<double>, double, 3>, double, Foam::divideEqOp2<double, double> > (vs=@0x7b0b10, s=@0x7fff08391d00, eo={<No data fields>}) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/VectorSpaceM.H:12 #2 0x000000000043ded3 in Foam::VectorSpace<Foam::Vector<double>, double, 3>:: operator/= (this=0x7b0b10, s=0) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/VectorSpaceI.H:236 #3 0x000000000044e49e in Foam::Field<Foam::Vector<double> >:: operator/= (this=0x77f480, f=@0x79bbb8) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/Field.C:716 #4 0x00002ba4a525ebef in Foam:: primitiveMesh::makeCellCentresAndVols (this=0x783180, fCtrs=@0x794190, fAreas=@0x79d0c0, cellCtrs=@0x77f480, cellVols=@0x79bbb0) at meshes/primitiveMesh/primitiveMeshCellCentresAndVols.C:158 #5 0x00002ba4a525ee55 in Foam:: primitiveMesh::calcCellCentresAndVols (this=0x783180) at meshes/primitiveMesh/primitiveMeshCellCentresAndVols.C:67 #6 0x00002ba4a525eeed in Foam:: primitiveMesh::cellVolumes (this=0x783180) at meshes/primitiveMesh/primitiveMeshCellCentresAndVols.C:180 #7 0x00002ba4a40164a1 in Foam::fvMesh::V (this=0x7830c0) at fvMesh/fvMeshGeometry.C:327 #8 0x00002ba4a403ae10 in Foam::fvMesh::movePoints (this=0x7830c0, p=@0x7dcd48) at fvMesh/fvMesh.C:515 #9 0x00002ba4a7945946 in Foam::movingConeTopoFvMesh::update (this=0x7830c0) at movingConeTopoFvMesh/movingConeTopoFvMesh.C:388 #10 0x00000000004357a2 in main (argc=1, argv=0x7fff08395168) at icoDyMFoam.C:67 Here is the same information with some detailed information of the variables in different frames 0-4: frame 0: (gdb) frame 0 #0 0x000000000043c38c in Foam::divideEqOp2<double, double>:: operator() (this=0x7fff08391cf0, x=@0x7b0b10, y=@0x7fff08391d00) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/ops.H:75 (gdb) info args this = (const Foam::divideEqOp2<double, double> * const) 0x7fff08391cf0 x = (double &) @0x7b0b10: 0 y = (const double &) @0x7fff08391d00: 0 frame 1: (gdb) frame 1 #1 0x000000000043de97 in VectorSpaceOps<3, 0>::eqOpS<Foam::VectorSpace<Foam::Vector<double>, double, 3>, double, Foam::divideEqOp2<double, double> > (vs=@0x7b0b10, s=@0x7fff08391d00, eo={<No data fields>}) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/VectorSpaceM.H:12 (gdb) info args vs = (Foam::VectorSpace<Foam::Vector<double>, double, 3> &) @0x7b0b10: {v_ = {0, 0, 7.1115353432685034e-32}} s = (const scalar &) @0x7fff08391d00: 0 eo = {<No data fields>} (gdb) info locals No locals. frame 2: (gdb) frame 2 #2 0x000000000043ded3 in Foam::VectorSpace<Foam::Vector<double>, double, 3>:: operator/= (this=0x7b0b10, s=0) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/VectorSpaceI.H:236 (gdb) info args this = (Foam::VectorSpace<Foam::Vector<double>, double, 3> * const) 0x7b0b10 s = 0 (gdb) info locals No locals. frame 3: (gdb) frame 3 #3 0x000000000044e49e in Foam::Field<Foam::Vector<double> >:: operator/= (this=0x77f480, f=@0x79bbb8) at /home/jaswi/OpenFOAM/OpenFOAM-1.5-dev-debug/src/OpenFOAM/lnInclude/Field.C:716 (gdb) info args this = (Foam::Field<Foam::Vector<double> > * const) 0x77f480 f = (const Foam::UList<double> &) @0x79bbb8: {v_ = 0x7a7eb0, size_ = 82} (gdb) info locals i = 76 frame 4: (gdb) frame 4 #4 0x00002ba4a525ebef in Foam:: primitiveMesh::makeCellCentresAndVols (this=0x783180, fCtrs=@0x794190, fAreas=@0x79d0c0, cellCtrs=@0x77f480, cellVols=@0x79bbb0) at meshes/primitiveMesh/primitiveMeshCellCentresAndVols.C:158 (gdb) info args this = (const class Foam:: primitiveMesh * const) 0x783180 fCtrs = (const vectorField &) @0x794190: {<Foam::refCount> = {count_ = 0}, <Foam::List<Foam::Vector<double> >> = {<Foam::UList<Foam::Vector<double> >> = {v_ = 0x79e150, size_ = 356}, <No data fields>}, static typeName = <optimized out>} fAreas = (const vectorField &) @0x79d0c0: {<Foam::refCount> = {count_ = 0}, <Foam::List<Foam::Vector<double> >> = {<Foam::UList<Foam::Vector<double> >> = {v_ = 0x7d5fd0, size_ = 356}, <No data fields>}, static typeName = <optimized out>} cellCtrs = (vectorField &) @0x77f480: {<Foam::refCount> = {count_ = 0}, <Foam::List<Foam::Vector<double> >> = {<Foam::UList<Foam::Vector<double> >> = {v_ = 0x7b03f0, size_ = 82}, <No data fields>}, static typeName = <optimized out>} cellVols = (scalarField &) @0x79bbb0: {<Foam::refCount> = {count_ = 0}, <Foam::List<double>> = {<Foam::UList<double>> = {v_ = 0x7a7eb0, size_ = 82}, <No data fields>}, static typeName = <optimized out>} (gdb) info locals own = (const labelList &) @0x7833b0: {<Foam::UList<int>> = {v_ = 0x7e8580, size_ = 356}, <No data fields>} nei = (const labelList &) @0x783420: {<Foam::UList<int>> = {v_ = 0x785f60, size_ = 136}, <No data fields>} cEst = {<Foam::refCount> = {count_ = 0}, <Foam::List<Foam::Vector<double> >> = {<Foam::UList<Foam::Vector<double> >> = {v_ = 0x7b0e20, size_ = 82}, <No data fields>}, static typeName = <optimized out>} nCellFaces = {<Foam::refCount> = {count_ = 0}, <Foam::List<int>> = {<Foam::UList<int>> = {v_ = 0x799fc0, size_ = 82}, <No data fields>}, static typeName = <optimized out>} As can be seen from the state of the variables in frame 0, there is zero by zero division (0/0) and it is causing the crash. Hope I was not wrong in pointing this out. I am in now way claiming that code is not functioning as described. I hope that some body might have met the same error and give me some tip. Thanks for the attention Kind Regards Jaswi |
Dear Jaswi,
sorry, I cannot reproduce your problem with revision 1208. May I suggest that you recompile everything from scratch. rmoall ./Allwmake Best Regards, Henrik |
Dear Henrik
The version I am using is latest. I am not sure which version was that but nevertheless I will update my source code and recompile. In the mean time could you please send me the case setup you tested. Kind Regards Jaswi |
