Home > Forums > OpenFOAM Running, Solving & CFD
add filed to OpenFOAM
Old   April 27, 2009, 10:50
Default add filed to OpenFOAM
Sven Degner
sven82 is on a distinguished road
Hi ,
at the moment I work with OpenFOAM especially with a new DES case.
After I finish the implementation I like to visual the individual zones (RANS or LES) with a easy 0 or 1, just to see in which zones work a RANS simulation and in which a LES
the idea
create a field in the turbulenceModell.C like this
DES_
IOobject
"DES",
runTime_.timeName(),
mesh_,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh_,
dimensionedScalar("DES", dimless, 0.0)
in the next step I create the two fields that I like to compare, and the turn
volScalarField keps_ = pow(sqrt(k_),3) / epsilon_;
volScalarField CDESdelta_ = CDES_ * delta();
if( keps < CDESdelta_ )
{DES_ = 1.0;}
else
{DES_ = 0.0;}
DES_.write();
But I got a problem when I run the case with my new DES, the field look like this
dimensions [0 0 0 0 0 0 0]; //Time 1e5 and NOT t=0
internalField uniform 1;
boundaryField
inlet
type calculated;
value uniform 1;
outlet
type calculated;
value uniform 1;
upperWall
type calculated;
value uniform 1;
lowerWall
type calculated;
value uniform 1;
My question now is whats wrong with the code.
The output of the values of the two compares parameters, CDESdelta and keps_, are correct (values of both possibilities , CDESdelta<keps and CDESdelta>keps) !
I hope anybody got a idea
best regards
sven
sven82 is offline   Reply With Quote
Old   April 27, 2009, 11:08
Henrik Rusche
henrik is on a distinguished road
Dear Sven,
DES_ = 1.0 sets the whole field to 1.0, likewise DES_ = 0.0;
You need a loop or translate the if into some function that is defined for fields.
Nice error, wonder what CDESdelta_ evaluates to in scalar context. Print it and enlighten me.
Henrik
henrik is offline   Reply With Quote
Old   April 28, 2009, 06:14
Henrik Rusche
Some more info on the gory details:
forAll(DES_, cellI)
    if( keps_[cellI] < CDESdelta_[cellI] )
    {DES_[cellI] = 1.0;}
    else
    {DES_[cellI] = 0.0;}
DES_.write();
Henrik
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
Adding jpeg picture file in OpenFoam post in add a message window kumar2 OpenFOAM 1 March 22, 2006 23:17
