Home > Forums > OpenFOAM Running, Solving & CFD
laminar RANSModel in dieselFoam
Old   April 29, 2009, 12:32
Default laminar RANSModel in dieselFoam
qhdgj is on a distinguished road
Dear all,
I am using 1.5version dieselFoam. I have several questions. Your help will be highly appreciated!
1. I could run my case with kEpsilon/RNGkEpsilon RANSModel, but the case goes to crash if I use laminar RANSModel, and I got the following error message. I wonder is it caused by the turbulent time scale calculation I found in dieselFoam.C? Does anyone know something about this?
Solving chemistry
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/dieselFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/dieselFoam"
#6 main in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/dieselFoam"
#7 __libc_start_main in "/lib64/libc.so.6"
#8 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/dieselFoam"
Floating point exception
2. I also got Evaporation Continuity Error message? any idea?
Number of parcels in system | 78
Injected liquid mass....... | 74285.7 mg
Liquid Mass in system...... | 74285.7 mg
SMD, Dmax.................. | 99.1116 mu, 149.87 mu
Added gas mass = 9.78229 mg
Evaporation Continuity Error| 9.78229 mg
ExecutionTime = 2.07 s ClockTime = 11 s
Courant Number mean: 0.016882 max: 0.0982951
deltaT = 0.00047619
Time = 0.0190476
3. what is the proper maxCourant number? I used 0.4 in the beginning, but in some cases I have to use 0.1 or 0.05.
4. I need to make sure what governing equations are being sloved, would you like to let me know where to start?
Thank you in advance!
-JG
qhdgj is offline   Reply With Quote
Old   April 29, 2009, 16:26
as for the Evaporation Continuity Error, I am running for non-evaporating spray and turn off the evaporation model.
Thread Tools
Trackbacks are On
Laminar doesn't converge; Turbulent models do? Amit FLUENT 11 April 23, 2015 22:55
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
How to enforce laminar flow while using k-e Grzegorz Kondora FLUENT 0 January 28, 2009 11:35
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 02:20
Differences between a laminar code and a les one ben Main CFD Forum 9 February 17, 2005 00:40
