spray source term in k-epsilon equations
Old   May 2, 2009, 15:31
Default spray source term in k-epsilon equations
Yejun Gong
yejungong is on a distinguished road
Hi OpenFOAMers
I am trying to add the spray source term to the k-epsilon equations?
the difficulty is that src/turbulenceModels/RAS/compressible/RNGkEpsilon has no interface to spray, furthermore, spray needs the runTime and Mesh info while turbulenceModels has not.
Thanks a lot
Best Regards
Yejun
yejungong is offline   Reply With Quote
Old   May 2, 2009, 15:38
Default You can get these two variable from U.
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Hi Yejun
You can get these two variables from U.
const Time & runTime=U.time();
const fvMesh &mesh=U.mesh();
Junwei
su_junwei is offline   Reply With Quote
Old   May 2, 2009, 15:57
Yejun Gong
thanks Junwei,
but there are still missing some inputs. indeed, turbulence model only has rho, U, phi and thermo as inputs, but spray needs p, T, composition of fuel, gasProperties and environmentalProperties.
but still thank you. your answer inspired me that I may need just change the inputs of turbulenceModels.
Yejun
Old   May 2, 2009, 19:45
su_junwei's Avatar
su junwei
Hi Yejun
The terms p, T, composition of fuel, gasProperties and environmentalProperties are not related to turbulence model. These terms can be defined outside the turbulence model. If you want to incorporate these terms into turbulence model without disturbing the interface, just defined several pointers in the turbulence model file, and set these pointers after constructing the turbulence model but before invoking the function "correct".
Another possible way is defining a variable for the source term you want to add, calculating it outside the class. Just update the source term variables defined every time step before invoking the "correct"
Regards, Junwei
Old   May 3, 2009, 11:18
Yejun Gong
Hi Junwei,
thanks a lot. I got it.
according to your suggestion, I just add one inputs spray& to the inputs of RNGkEpsilonModel. and looks like it's much better. However, I also need change RASModel when it calls the RNGkEpsilonModel. I am still considering whether do I need to make such a big change.
maybe I need just make a new turbulenceModel module which always has spray source terms added.
thanks again.
Yejun
Old   May 3, 2009, 11:33
su_junwei's Avatar
su junwei
Yes you have to change the whole framework if you changed the interface.
Junwei
Old   May 4, 2009, 02:13
xinguang cui
flying is on a distinguished road
I also think you only need to change the turbulence model. The turbulence model is given seprately with the spray, you don't need to change the source code.
flying is offline   Reply With Quote
Old   May 4, 2009, 11:23
Yejun Gong
thanks a lot. I have already rebuild the framework by add a new sprayRAS folder to the turbulence Models. and let sprayRAS and sprayRNGkEpsilon call each other. and the compilation has passed.
thanks again.
Yejun
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
