Problem with modified dieselEngineFoam
I'm running a modified version of dieselEngineFoam where layering is implemented. I'm running it on a 2D axi-symmetric mesh made with the blockMesh tool. When I'm running it with a grid of 60(large)x90(height) cells, all work fine. When I try to increase the number of cells over 90, I have this error message after a few steps: Courant Number mean: 0.0051238 max: 0.179441 Crank angle = -174 CA-deg deltaZ = 1.84629e-05 Piston at:0.0114478 pistonLayerID: 0 Piston layering mode Cell 2220 is marked as removed but still has faces. Cell faces: 2 ( 4(4514 4515 4576 4575) 4(4636 4637 4698 4697) ) From function Foam::autoPtr<Foam::mapPolyMesh> Foam::polyTopoChanger::changeMesh ( polyMesh& mesh, const polyTopoChange& ref ) in file polyTopoChange/polyTopoChanger/polyTopoChangerChangeMesh.C at line 620. FOAM aborting Aborted I don't understand where it comes from, does one of you have any suggestion ? Thank you for your help ! |
