error about timeVaryingUniformFixedValue
Old   June 11, 2009, 04:59
Default error about timeVaryingUniformFixedValue
xinguang cui
flying is on a distinguished road
Hey foamers!
I wish all of you have a good holiday.
I am trying to use the timeVaryingUniformFixedValue patch. But there is some error information as follows:
/OpenFOAM/cui-1.5/run/Project/Simplied_circular_geometry/Oodlagrangian/test/0/U::INLET"
file: /home/cui/OpenFOAM/cui-1.5/run/Project/Simplied_circular_geometry/Oodlagrangian/test/0/U::INLET from line 25 to line 27.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 213.
Would you like to give me some advice about it?
Moreover, Does anybody know the tutorial for the patch?
Thanks and Best wishes!
flying is offline   Reply With Quote
Old   June 12, 2009, 08:21
xinguang cui
Is there anybody caring about this problem?
I wish there will be good advice on it.
Old   June 14, 2009, 13:15
norman1981's Avatar
Norman Del Puppo
norman1981 is on a distinguished road
could you post your U file? Looking at your errors it seems that your inlet bc is hill posed (maybe your timeVaryingUniformFixedValue is not well set).
Norman
norman1981 is offline   Reply With Quote
Old   June 17, 2009, 03:21
xinguang cui
Hey Norman:
I am really sorry to reply late because I was out of work.
This is the U file
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
INLET
type timeVaryingUniformFixedValue;
fileName "inlet.dat";
boundAction repeat ;
OUTLET
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
WALL1
type fixedValue;
WALL2
type fixedValue;
WALL3
type fixedValue;
WALL4
type fixedValue;
In addition, I didn't give timeSeries file because I really don't know how to give it.
Would you like to tell me the tutorial for using this patch?
Thanks and best wishes!
Old   June 17, 2009, 03:54
norman1981's Avatar
Norman Del Puppo
don't worry ;-)
Try setting the INLET in this way:
INLET
// value uniform (0 0 0); //Un-comment it if OF complaints..
fileName "series.dat"; // You can change the filename...
outOfBounds clamp;
Put a "series.dat" file in your case directory. The "series.dat" file has this format:
(time_1 (vx_1 vy_1 vz_1))
(time_2 (vx_2 vy_2 vz_2))
(time_n (vx_1 vy_1 vz_1))
Please, note I used this bc in OpenFOAM-1.5.x version. I have not found a way to use it in OpenFOAM-1.5-dev although it is present in the source code.
Regards
Norman
Old   June 17, 2009, 04:49
xinguang cui
Thanks a lot for your reply. It is so helpful that I have solved the problem.
If you would like to spend your cherish time to answer my other question, I will be more grateful.
In fact, the velocity in the inlet boundary not only change with time, but it is also needed to add some fluctuation on it. It means that I need to use turbulence inlet boundary as well.
Would you like to give me some advice on how to use it?
