OpenFOAM machine loads for parallel runs
Old   May 27, 2009, 05:45
Default OpenFOAM machine loads for parallel runs
Rishi .
hellorishi is on a distinguished road
Hello All,
I have observed that when I use multiple CPUs of the same node is the machine load is quite high (higher than number of proc). In comparison, CFX usually does not behave like this. I observed this pattern with different OF solvers: simpleF, turbF, dieselF, etc.
E.g.
-When running a job with 4 processes on a Quadcore machine, the load it higher than 4 (~5).
-Even on dual cores load is typically higher ~2.7
(all AMD Opteron machines & used exclusively for OF)
When I use a different (master) node to start a run, then slave nodes have "normal loads = num of Proc".
To avoid this overloading issue, I am using one CPU for mpirun (i.e. Running with #CPU-1 --- 3 proc on quadcore)
It seems that mpirun is responsible for this extra load. Does this mean that OF is not using the CPUs in optimum manner? My guess: when load is more than 100% it is not optimum.
Any comments?
Rishi
hellorishi is offline   Reply With Quote
Old   May 27, 2009, 17:30
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
A load average slightly higher than one is not necessary very bad. I think a better metric is CPU time vs. walltime. If walltime is not roughly equal to (CPU time / NCPUs), then your parallelization is not very good.
akidess is offline   Reply With Quote
New building machine for OpenFoam gerbervdgraaf OpenFOAM Installation 23 December 9, 2009 02:39
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Distribution by Virtual Machine will OpenFOAM Installation 5 June 20, 2008 08:11
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
