May 28, 2009, 03:59 |
Internal field manipulation on run-time
Martin Tek
Rep Power: 16 |
Dear foamers,
I would like to ask sth closely related to my different thread: http://www.cfd-online.com/Forums/ope...-programs.html I have an equation e.g. k(x)*gradČu(x) with u as sole DOF and want to manipulate k(x) on run-time, e.g. inserting material inhomogeneities. But I would like to do this on runtime. Can you lead me in the right direction - which modifications are necessary to an existing solver? Thanks a lot, Martin |
May 29, 2009, 09:51 |
Henrik Rusche
Rep Power: 18 |
Dear Martin,
the last section of my reply to your other thread contains a code snippet that should give you an idea about how to change a field at runtime. If not, please let us know where exactly your problem lies. Henrik |
June 3, 2009, 18:11 |
Martin Tek
Rep Power: 16 |
Dear Henrik,
again thanks for your help. I will continue commenting in the other thread, actually, I think I had only one problem. Martin |
Physical Reason for stability of Implicit Schemes? | radhakrishnan | Main CFD Forum | 26 | October 3, 2023 22:05 |
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic | sponiar | OpenFOAM Meshing & Mesh Conversion | 2 | March 30, 2009 15:02 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
Total run time | Dominic | Main CFD Forum | 0 | August 24, 2006 23:12 |
