Garbage collector and memory used in the system
Old   May 27, 2009, 09:17
Default Garbage collector and memory used in the system
Virginie Ehrlacher
virginie_e is on a distinguished road
Hello Foamers,
I am sorry to ask such a stupid question but I did not find any thread on the subject. How can we call the garbage collector of C++ in OpenFOAM syntax and how can we see the size of the memory allocated during the simulation?
I tried the following command lines:
System.GC.Collect();
and
Console::WriteLine("memory allocated", Environment::WorkingSet);
but I got some error messages such as Console, Environment and System have not been declared. This may be just a question of C++ and of package to load. I beg your pardon for polluting the forum if it is the case but some help would be very much appreciated.
Thank you in advance
Virginie
virginie_e is offline   Reply With Quote
Old   May 28, 2009, 11:19
Assistant Moderator
Bernhard Gschaider
Originally Posted by virginie_e View Post
Hello Foamers,
and
Virginie
There is no garbage collector in C++. Not unless you use a library that implements one. The programmer is responsible for freeing memory. To have something similar to garbage collection OF has the templates autoPtr and tmp
Bernhard
Old   May 28, 2009, 21:57
Henrik Rusche
henrik is on a distinguished road
Dear Vergine,
yes, no garbage collecion in C++.
If "top" is good enough, you can profile the memory comsumption using getrusage. Consult the man page for details.
Henrik
henrik is offline   Reply With Quote
Old   May 29, 2009, 08:00
Assistant Moderator
Bernhard Gschaider
Or you can use (beware: advertisment) the pyFoamRunner-Utilities. They have an option --report-usage which at the end of the run reports the maximum-memory consumption encountered. Only works for serial though and not on every system
Bernhard
