June 18, 2009, 09:31 |
Error with 'vanAlbada' scheme
Julian Krick
Rep Power: 16 |
Hallo,
I'm using the sonicFoam solver for my flow problem. For the discretization of the convective terms I'd like to use the the 'vanAlbada' scheme. Here is the excerpt from my /system/fvSchemes file: Code:
... divSchemes { default none; div(phi,U) Gauss vanAlbada; div(phid,p) Gauss vanAlbada; div(phi,e) Gauss vanAlbada; } ... Code:
... Create time Create mesh for time = 0 Reading thermodynamicProperties Reading transportProperties Reading field p Reading field T Calculating field e from T Reading field U Reading/calculating face flux field phi Starting time loop Time = 1e-08 Lookup interpolationScheme for interpolate(rho) Courant Number mean: 0 max: 0 Lookup ddtScheme for ddt(rho) diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 Lookup laplacianScheme for laplacian(mu,U) Lookup fluxRequired for U Lookup gradScheme for snGradCorr(U) Lookup gradScheme for snGradCorr(U) Lookup gradScheme for snGradCorr(U) Lookup divScheme for div(phi,U) Lookup gradScheme for grad(magSqr(U)) Lookup ddtScheme for ddt(rho,U) Lookup gradScheme for grad(p) DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 3.76603e-12, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 8.97676e-10, No Iterations 1 Lookup gradScheme for grad(U) Lookup interpolationScheme for interpolate(rho) Lookup laplacianScheme for laplacian(mu,e) Lookup fluxRequired for e Lookup gradScheme for snGradCorr(e) Lookup divScheme for div(phi,e) Lookup gradScheme for grad(e) #0 Foam::error::printStack(Foam::Ostream&) in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::LimitedScheme<double, Foam::vanAlbadaLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::limitedSurfaceInterpolationScheme<double>::weights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::fv::gaussConvectionScheme<double>::fvmDiv(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) const in "/home/julian/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/home/julian/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicFoam" #7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/julian/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicFoam" #8 main in "/home/julian/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicFoam" #9 __libc_start_main in "/lib64/libc.so.6" #10 Foam::regIOobject::readIfModified() in "/home/julian/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/sonicFoam" Gleitkomma-Ausnahme Does anyone have a suggestion? Thanks for reading my thread, bye Julian
grid generation: ICEM CFD 13.0 solver: CFX 13.0 |
Implementation of QUICK scheme | Romuald Skoda | Main CFD Forum | 11 | November 6, 2017 21:20 |
AUSM scheme ? Central Scheme | boling | Main CFD Forum | 7 | January 7, 2016 02:41 |
Definition of limiter function for central dirrerencing scheme | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | January 5, 2009 11:08 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
extrapolation in MUSCL scheme | Chandra | Main CFD Forum | 6 | February 14, 2007 11:21 |
