interFoam ask for a value in a nutkRoughWallFunction |
October 30, 2013, 08:01 |
Antonio
Rep Power: 13 |
I have defined a rough wall bc using nutkRoughWallFunction, in this way (0/nut):
object nut; [...] boundaryField { wall { type nutkRoughWallFunction; Ks uniform 0.0001; Cs uniform 0.5; } Code:
Example of the boundary condition specification: \verbatim myPatch { type nutkRoughWallFunction; Ks uniform 0; Cs uniform 0.5; } \endverbatim Code:
0/nut.boundaryField.wall from line 26 to line 28. From function fvPatchField<Type>::fvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict,const bool valueRequired) in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/fvPatchField.C at line 162. FOAM exiting Why is it asking for a value field, if the wall function does not need it? If I put any value, Would it be used for anything? I mean, if I add a "value uniform 0;", it won't influenced anything, will it? Thank you in advance! |
August 13, 2014, 08:46 |
Olivier Benichou
Rep Power: 15 |
same problem here
August 14, 2014, 03:49 |
It is just needed for the first iteration and will be overwritten afterwards, so just put uniform 0, or maybe a small value.
boundary condition, wall boundary condition |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 06:36 |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Problem of InterFoam with LES SpalartAllmarasIDDES | keepfit | OpenFOAM | 3 | August 29, 2013 11:21 |
Gravity & pressure handle in interFoam | dav.dap83 | OpenFOAM Programming & Development | 2 | May 22, 2013 11:21 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 21:58 |
