Diffuse Interface Method in interFOAM
Like Tree1Likes
  • 1 Post By 4xF
Old   May 27, 2009, 07:52
Default Diffuse Interface Method in interFOAM
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
I am a new guy with OF and I am working in multiphase flow. As I knew, in order to physically describe the interface, a new method called Diffuse Interface Method is introduced. Does any one know whether is is implemented in OF 1.5?
Thanks,
Anh Duong
duongquaphim is offline   Reply With Quote
Old   June 12, 2009, 10:17
Default About the diffuse interface method
4xF
Frank Albina
4xF is on a distinguished road
Send a message via Skype™ to 4xF
The diffuse interface method assumes that the interface is described by the spatial variation of a variable. In the VOF method, this is the scalar representing the limit between two fluids. In level set methods, this is the level function itself. Typically, the variations of the variable are noticeable only in the vicinity of the interface, which is usually spread over 2 to 3 control volumes.
From there, the diffuse interface methods states that the forces acting at the liquid/gas interface such as surface tension are represented by volumetric forces which are everywhere zero but at the interface. Since the interface representation is spread over 2 or 3 control volumes, so is the volumetric force. The usual jump condition at the interface ( sigma*curvature for pressure) is thus smeared over the interface representation. In the diffuse interface model, this jump condition is recovered by integrating the volumetric force along the interface normal. Should the interface thickness tend to zero, the jump condition is then recovered.
So, in conclusion, if you look at the InterFoam solver, it implements the diffuse interface model...
Hope this helps...
Pirlu likes this.
4xF is offline   Reply With Quote
Old   June 26, 2009, 05:16
Duong A. Hoang
Hi Frank,
Thank you for your answer. As you mention, I checked the InterFoam solver and gammaEqn.H. However, in this solver, they only solve a convective equation of gamma and I did not find anything relating to Diffuse Interface method.
Is it true that you were mentioning about compressive gamma coefficient? I think these two methods are different.
Can you please show me some lines in interFoam solver code about this?
Duong
smoothed interface capturing method: compressible. jinwon Main CFD Forum 0 May 14, 2007 00:20
diffuse interface model KK-Khan Main CFD Forum 0 July 14, 2006 03:26
interface reconstruction in Fluent VOF method? daniel FLUENT 0 May 4, 2006 03:46
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
