Howto get the production and dissipation of TKE??
Anyone knows how to get the production and dissipation of TKE (turbulence kinetic energy)? Thanks
Is it in this way: Code:
volSymmTensorField D = symm(fvc::grad(U)); |
Production and dissipation of TKE
Dear Daniel
I am also interested in this topic. Therefore, I would like to know if you found an answer to your question in the meantime. Cheers, Irina |
Sorry, it'e been a long time, but doesn't the codes in my last post work for you?
you can try with a channel case and see if its distribution is correct. Bye |
why did you take the symmetrical part of grad(U) ? Why didn't you compute Code:
R && fvc::grad(Umean) Regards, JD |
Notice that the method epsilon() returns the SGS dissipation rate. Check doxygen to see how it is computed, depending on the specific model.
Hi Alberto,
thank you for your answer. When I take a look at src\turbulenceModels\LES\incompressible\oneEqEddy\ oneEqEddy.C, I read: Code:
void oneEqEddy::correct(const tmp<volTensorField>& gradU) Code:
ce_*sqrt(k_)/delta() Code:
2.0*nuSgs_*magSqr(symm(gradU)) I also do not understand why the symmetric part of the gradient of U is mentionned in the previous post. Regards, JD |
The double-inner product of a symmetric and asymmetric second-rank tensor is zero, so in that sense, only the symmetric part of gradU "survives" anyway. So using only the symmetric part is harmless, but perhaps unnecessary.
volScalarField epsilon = sgsModel->epsilon(); does not return what you want. That epsilon is only the SGS epsilon. Since you do DNS, just apply the definition and you will be fine :-) Best, |
This is an old thread, but I wonder if anyone has achieved a reliable method to calculate TKE dissipation?! Regards |
Dear Johndeas, Did you find any way out ? I'm also stuck at the same state. :confused: |
