Rotational averaging in a circular container/mesh
Old   July 3, 2009, 03:51
Question Rotational averaging in a circular container/mesh
Stefan Roth
Shany is on a distinguished road
Hello everyone,
I have a little problem doing some calculations on geometric Fields. Since I'm very new to OpenFOAM I'm sure there's some very easy solution I'm just failing to figure out.
We have a circular mesh and simulate with LES the rotation and turbulence of a fluid inside. The walls are set to a certain rotation speed, heating temperature and so on...
What I try to accomplish is an averaging procedure, that circulary averages the temperatures (T) and fluid speeds (U) .. or any other geometric field we might need in the future. Best described as making slices every one degree and then average over the slices to get mean temperature and velocity distribution in a rotational sense in the fluid.
The idea I investigated last, was to create a copy of the mesh, rotate this and use the meshToMesh class to interpolate the rotated fields back on the original mesh. Reading the second mesh simply from disk would work, but is unwanted as I would have t make a save/read operation of the mesh with each timestep.
creating a mesh in this way:
Foam::fvMesh rotatedMesh
IOobject
Foam::fvMesh::defaultRegion,
runTime.timeName(),
runTime,
Foam::IOobject::NO_READ,
Foam::IOobject::NO_WRITE
mesh.points(),
mesh.faces(),
mesh.cells(),
true
and then using meshToMesh fails because he requires the patches to be set correctly
rotatingField = transform( Ten, rotatingField );
rotatedMesh.movePoints( rotatingField );
meshToMesh meshToMeshInterp( rotatedMesh, mesh );
meshToMeshInterp.interpolateInternalField
(*(AAscalarFields.begin())).internalField(),
originalField,
meshToMesh::INTERPOLATE
Right now I'm working in reading the boundary from the disk but my question is: can't this be done in a much simpler way?
Thanks in advance!
Shany is offline   Reply With Quote
Old   July 6, 2009, 05:25
Henrik Rusche
henrik is on a distinguished road
Dear Shany,
I have not looked into your approach in detail. So I won't comment whether it will work or is a good idea.
However, I would go about this by calculating cylindrical coordinates
volScalarField Phi = atan2(mesh.C().y(), mesh.C().x());
Here, I assume that the mesh is aligned with the z-coordinate.
Now you can walk through the Phi and collect your statistics as needed. If this is too expensive, you may create addressing for each sector.
Henrik
henrik is offline   Reply With Quote
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Averaging LES iko FLUENT 3 July 3, 2008 05:55
conjugate heat transfer in circular channel src FLUENT 1 August 6, 2004 07:13
