Question about field defintion
I have a question concerning the definition of fields, either vectorial or tensorial, for CFD calculations. In
particular, during my calculations I have to calculate the gradient of velocity field, by defintion a volVectorField, using the formula DU = fvc :: grad (U); Both DU and U are defined in the file createFields.H, in the following form // Reading the velocity field Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Creating Velocity Gradient Tensorial Field\n" << endl; volTensorField DU ( IOobject ( "DU", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), fvc::grad(U) ); This way, I ensure that in each mesh point I calculate correctly DU, right? Other form could be doing the following volTensorField DU = fvc :: grad ( U() ); I believe the first form is correct, although the second may work. Can anybody help me out? Regards, Titio |
Dear Titio,
Both forms are possible and the second will work if you delete the brackets on U. volTensorField DU = fvc::grad (U); Henrik |
