-   -   Difference between codes and representations (http://www.cfd-online.com/Forums/openfoam-solving/65984-difference-between-codes-representations.html)
titio July 2, 2009 11:59
Hi Foamers,
I have a small question concerning relaxation. Is there any difference, when writting the code, between the
following forms of relaxation, when solving the Navier stokes equation for laminar flow of newtonian fluids.
Form 1
fvVector UEqn
fvm::ddt(U)
+ fvm::div(phi,U)
- fvm::laplacian(nu,U)
UEqn.relax();
solve (UEqn == -fvc:: grad(p));
Form 2
fvVector UEqn()
fvm::ddt(U)
+ fvm::div(phi,U)
UEqn().relax();
solve (UEqn() == -fvc:: grad(p));
Is there any significant difference between the two formulations.
Thanks,
Titio
gschaider July 2, 2009 14:10
No. The second UEqn is probably a autoPtr of a fvMatrix.
henrik July 3, 2009 03:32
Hi Titio,
Bernhard is absolutely right.
Form 2 (and Form 1) are quoted incorrectly. Form 2 should read:
tmp<fvVectorMatrix> UEqn
fvm::ddt(U)
+ fvm::div(phi,U)
(see simpleFoam)
By using tmp (or alternatively autoPtr) one is able throw away the U-Matrix before solving the p-equation. This way, you can save some peak-memory in steady-state solvers.
Regards, Henrik
gschaider July 3, 2009 07:58
... and to short to be understood. I planned to add a second sentence "This is only an 'administrative' construct and doesn't change the physical meaning of the equation" and obviously forgot that.
But Henrik's answer is better anyway
