-   -   mistake after nparcels increased, dieselFoam (http://www.cfd-online.com/Forums/openfoam-solving/66214-mistake-after-nparcels-increased-dieselfoam.html)
yejungong July 9, 2009 04:45
I am running my version of dieselFoam using osx system. and my code works fine when nparcels=5000.
but after I increased the number of parcels, nparcels, to 20000, I got the following error messages, attached in the bottom.
I have installed binutils which includes gaddr2line.
is it happened because of osx system?
Any help is highly appreciated!
Yejun
Evolving Spray
#0 Foam::error::printStack(Foam::Ostream&)unable to read unknown load command 0x1b
unable to read unknown load command 0x1e
in "/Network/Servers/controller.cluster/Homedir/yegong/OpenFOAM/OpenFOAM-1.5/lib/darwinIntelDPOpt/libOpenFOAM.dylib"
#1 Foam::sigSegv::sigSegvHandler(int)unable to read unknown load command 0x1b
#2 _sigtrampgaddr2line: /usr/lib/libSystem.B.dylib: cannot get addresses from archive addr2line failed
#3 _sigtrampgaddr2line: /usr/lib/libSystem.B.dylib: cannot get addresses from archive
addr2line failed#4 void Foam::Cloud<Foam::parcel>::move<Foam::spray>(Foam: :spray&)unable to read unknown load command 0x1b
unable to read unknown load command 0x1e in "/Network/Servers/controller.cluster/Homedir/yegong/OpenFOAM/yegong-1.5/lib/darwinIntelDPOpt/libmydieselSpray.dylib"
#5 Foam::spray::move()unable to read unknown load command 0x1b
#6 Foam::spray::evolve()unable to read unknown load command 0x1b
gschaider July 9, 2009 05:31
Originally Posted by yejungong (Post 222020)
I doubt, that the extra 15k particles pushed it over the edge memory-wise, but have you checked how much memory the 5k-case needed?
BTW: is this the first time-step with particles?
I doubt it. The "unable to read unknown load command 0x1b" is an OS X-problem. But it was not the cause of the catastrophe.
Yejun
Evolving Spray
0x1b
sigSev points to a "I accessed an address outside of an array"-problem. Which leads to the usual mantra: "have you got a debug-version handy"
Bernhard
yejungong July 9, 2009 05:44
thanks, Bennard,
this error message happened after the injected parcels accessed 8000, not the first time step. and if I use nparcels=8000, my code works.
the 8000 case needs around 120M memory. and I have 8GB of memory. it should be enough.
Yejun
yejungong July 9, 2009 05:53
Bernhard
sorry, what's "debug-version handy"?
I do defined some new variables in my code, but they are all pointers or scalars. no one is array.
gschaider July 9, 2009 10:47
What I meant to say was: compile yourself a debug-version of OF (see for instructions elsewhere on the forum) and run your program in that. Most causes for segmentation-faults ("array out of bounds" basically) are checked for in the debug-version
No matter what you do: as soon as you start developing you should have a debug-version. It saves you a lot of time
yejungong July 10, 2009 03:17
thanks a lot, Bernhard.
I have compiled the debug version, and I will learn how to use it first.
Yejun
