VOF method +surface tension
Old   July 9, 2009, 18:10
Default VOF method +surface tension
Ramesh Yapalparvi
yapalparvi is on a distinguished road
Hi ,
Has anybody implemented VOF method incorporating surface tension effetcs. In the tutorial given, the surface tension has been neglected . Many thanks
Ramesh
yapalparvi is offline   Reply With Quote
Old   July 11, 2009, 05:23
Henrik Rusche
henrik is on a distinguished road
Ramesh,
I don't know which tutorial you are refering to, but surface tension (transportProperties::sigma) is definitely taken into account in the damBreak tutorial.
Henrik
henrik is offline   Reply With Quote
Old   July 12, 2009, 10:37
Ramesh Yapalparvi
Henrik,
Yes, the surface tension has been prescribed in the dam break problem. I would like to know whether any problem has been solved using openFOAM which involves boundary conditions prescribed by means of surface tension at the interface
Old   July 12, 2009, 14:46
Henrik Rusche
Dear Ramesh,
there is a formulation for the contact angle which has originally been used for simulations of meandering rivulet flows. See here:
http://www.cfd-online.com/Forums/ope...act-angle.html
Henrik
Old   July 16, 2009, 17:32
Ramesh Yapalparvi
Hi Henrik,
Could you please tell me where is this file interfaceProperties.C located. I could see that interfaceProperties.H is included in interFoam.C . Can I also know where are the headers files which are used in the solvers are located?. Thanks
Ramesh
Old   July 17, 2009, 03:56
Jean-Peer Lorenz
jploz is on a distinguished road
just have a look at the file 'Make/options'. Compiler includes etc. for the specific solver/lib are defined within this file. Then follow the specified paths.
Alternatively you could use the 'Search file' functionality provided by your operation system or use the (online) doxygen documentation (also provides search functionality).
Regards.
jploz is offline   Reply With Quote
VOF && surface tension -- PROBLEM bohis FLUENT 3 May 29, 2011 16:35
Surface Tension Force Model Miguel CFX 7 October 2, 2006 05:30
Concentration dependent surface tension ling FLUENT 0 July 25, 2006 13:47
VOF SURFACE TENSION EFFECTS ozgur FLUENT 0 March 26, 2004 03:36
UDF for surface tension gradient kiran FLUENT 2 July 15, 2003 12:00
