Waves in simple channel
Old   July 17, 2009, 06:59
Default Waves in simple channel
taranov is on a distinguished road
Hello, forum!
I'm starting to learn the OpenFOAM and have a newbie question.
I would like to simulate the flow in very simple geometry:
a 2-phase parallelepiped with air-water interface. Without walls and bodies.
The OF version 1.5, the solver - interFoam. maxCo=0.3
The problem is as follows: at leading edge of free surface (at inlet)
raises the high value of velocity, which lead to raising of waves.
See attached pictures. Please advise how to avoid this problem.
Boundary conditions:
gamma:
in_air uniform 0;
in_water uniform 1;
out_water zeroGradient;
out_air zeroGradient;
top slip;
bottom slip;
side slip;
pd:
in_air zeroGradient;
in_water zeroGradient;
top slip;
bottom slip;
side slip;
U:
in_air uniform (1 0 0);
in_water uniform (1 0 0);
top slip;
bottom slip;
side slip;
fvSolvers:
solvers
pcorr PCG
preconditioner DIC;
tolerance 1e-10;
relTol 0;
pd PCG
preconditioner DIC;
tolerance 1e-7;
relTol 0.05;
pdFinal PCG
preconditioner DIC;
tolerance 1e-7;
relTol 0;
k PBiCG
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
omega PBiCG
tolerance 1e-05;
relTol 0.1;
U PBiCG
tolerance 1e-06;
relTol 0;
PISO
momentumPredictor no;
nCorrectors 3;
nNonOrthogonalCorrectors 0;
nGammaCorr 1;
nGammaSubCycles 2;
cGamma 1;
pdRefCell 1;
pRefCell 1;
pRefValue 1;
pdRefValue 0;
fvSchemes:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(U) Gauss linear;
grad(gamma) Gauss linear;
divSchemes
div(rho*phi,U) Gauss limitedLinearV 1;
div(phi,gamma) Gauss vanLeer;
div(phirb,gamma) Gauss interfaceCompression;
div(phi,omega) Gauss upwind;
div(phi,k) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
pd;
pcorr;
gamma;
Thanks in advance
Andrey
taranov is offline   Reply With Quote
Why wallGradU result is different from dudy in the smooth channel bed xiuying OpenFOAM Running, Solving & CFD 12 March 2, 2009 07:58
simple airflow through a box channel Leo Lau FLUENT 4 October 14, 2007 05:23
SIMPLE Scheme for open channel flow ao Main CFD Forum 0 April 6, 2004 16:21
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 04:59
