New AMG Solvers in OF141dev SVN
Like Tree4Likes
  • 1 Post By philippose
  • 3 Post By hjasak
Old   October 27, 2007, 14:05
Default Hello and a Good day :-)! I
Philippose Rajan
philippose will become famous soon enough
I just finished compiling the latest SVN version of OpenFOAM-1.4.1-dev, and was generally looking around the sources, and found that there are new AMG solvers available....
Where could I get more information regarding what the advantages / disadvantages of, and the situations in which the following solvers can be used:
a. fpeAmgSolver
b. mpeAmgSolver
c. rreAmgSolver
d. amgSymSolver
And also... the following solvers:
d. bicgStabSolver
e. cgSolver
f. deflationSolver
g. gmresSolver
In addition, what do the "AMG Policies" do? There too.. there seem to be a couple of options. I remember finding a paper by Hrv some time ago with a performance comparison of some of these solvers, but I cant seem to find that paper now!
Have a great weekend!
Philippose
mm.abdollahzadeh likes this.
philippose is offline   Reply With Quote
Old   October 27, 2007, 17:34
Default A paper, of course: http:/
Hrvoje Jasak
A paper, of course:
http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/papers/CFD2007CanadaPrecon.pdf
and
http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/papers/CFD2007CanadaExtrapolation.pdf
Enjoy,
Hrv
Hrvoje Jasak
Old   October 27, 2007, 19:04
Default Hello Hrv :-)! Thanks a lot
Philippose Rajan
Hello Hrv :-)!
Thanks a lot for those two papers.... the first of those two was the one I had seen earlier, and the one I was referring to in the post :-)!
And... nice to hear from you after a long time too !
Shall read through those two tomorrow... and see if its applicable to the simulations I work on.
Regards,
Philippose
Old   October 28, 2007, 10:24
Default I just compiled the OpenFOAM-1
Qiang Li
frank is on a distinguished road
I just compiled the OpenFOAM-1.4.1-dev- 26oct version, got a error. I guess GAMG solver setting changes.
Hrv, please give me a hint!
PBiCG: Solving for alpha, Initial residual = 0.00018123, Final residual = 1.09717e-20, No Iterations 1
Dispersed phase volume fraction = 0.275 Min(alpha) = 0 Max(alpha) = 0.55
PBiCG: Solving for alpha, Initial residual = 5.20764e-06, Final residual = 4.23583e-22, No Iterations 1
Dispersed phase volume fraction = 0.275 Min(alpha) = -2.85747e-101 Max(alpha) = 0.55
--> FOAM FATAL IO ERROR : Cannot read control minIter
file: -1.4.1-dev/run/twoPhaseEulerFoam/bed/system/fvSolution::p from line 29 to line 40.
From function void lduMatrix::solver::readControl
const dictionary& controlDict,
T& control,
const word& controlName
in file matrices/lduMatrix/lduMatrix/lduMatrixTemplates.C at line 57.
FOAM aborting
Aborted (core dumped)
Li Q
frank is offline   Reply With Quote
Old   October 28, 2007, 10:59
Default This problem have been solved
Qiang Li
This problem have been solved through system/controlDict
solvers
p GAMG
minIter 0; //
maxIter 500; //
tolerance 1e-8;
relTol 0;
smoother DIC;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
scaleCorrection true;
directSolveCoarsest false;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
Li Q
Old   October 28, 2007, 15:35
Default Simply, I don't like the idea
Hrvoje Jasak
Simply, I don't like the idea of hidden optional parameters, so I've made them all required. minIter tells you how many solver sweeps will be forced without checking the convergence tolerance: usually zero.
Hrv
Hrvoje Jasak
Old   November 21, 2007, 10:24
Default Hi, ... it seems that the
Fabian Braennstroem
braennstroem is on a distinguished road
... it seems that the last post got lost....
I wondered how the the GAMG solvers are implemented in 1.4.1-dev? As I read the old AMG solver were transfering there data at every level in a parallel setup. Is it the same procedure for the new solver? Isn't it possible to do the interchange just at the finest level and pass the value to the coarse one; a lot of transfer time could be saved?
Fabian
braennstroem is offline   Reply With Quote
Old   November 26, 2007, 04:29
Default Hi,Prof. Hrvoje Jasak Your AM
Harry
harry is on a distinguished road
Your AMG solver sounds amazing. I plan to use it in my specific multiphase CFD code, but do not want to completely give up my own in-house code. This is possible or not? I mean have you planed to release it as a independent solver of linear equations,in particular for CFD, as done by hype and PETSc?
Regards,
Harry
harry is offline   Reply With Quote
Old   July 27, 2009, 14:52
John Deas
johndeas is on a distinguished road
Would it be possible to have an example case of the fastest one from the paper, in order to test the performance easily, and quickly use it on own cases ? For example, the rreAmg ?
johndeas is offline   Reply With Quote
OF141dev undefined reference to METIS symbols on SUSE Enterprise matthias OpenFOAM Installation 5 August 29, 2008 10:55
OF141dev installation Woes chegdan OpenFOAM Installation 13 July 18, 2008 17:16
Compiling OF141dev with GCC430 matthias OpenFOAM Installation 5 June 23, 2008 13:39
Installation of OF141dev on redhatEL 64bits problems with Allmake young OpenFOAM Installation 3 May 1, 2008 00:42
Solvers DB Siemens 3 December 6, 2005 08:26
