-   -   nonuniform velocity at the inlet (http://www.cfd-online.com/Forums/openfoam-solving/67013-nonuniform-velocity-inlet.html)
sambatra July 31, 2009 03:20
Hi there,
It's been a while,
I'm actually implementing boundary condition of the velocity at the inlet,the thing is that the velocity at the inlet is nonuniform
in fact for my case, the inlet is split into three portions and each portion has its own velocity,here what I tried:
inlet
type fixedvalue;
value nonuniform<Listvector>
100
But it didnt work!!!
for more information, the field is rectangular with 100*50 cells
the width contains 50 cells
the length contains 100 cells
and inlet is along the length.
Can anybody help me out?Please
Best Regards!
sega July 31, 2009 03:27
I think
inlet
    type      fixedvalue;
    value    nonuniform List<vector> 100
          (0 0 0)
          (0 0 1)
is the right syntax in your case!
sambatra July 31, 2009 05:42
thanks for the information I will try it.
Best regards
Prash October 20, 2012 12:13
Hi Guys,
I am stuck same problem. Has anybody tried this snippet
inlet { type fixedvalue; value nonuniform List<vector> 100 ( (0 0 0) (0 0 1) ... ); }
I could not get it to run, appreciate your help.
fcollonv October 23, 2012 03:29
Hi Prash,
OpenFOAM is case sensitive. Try
inlet
    type fixedValue;
    100(
    (0 0 0)
Remark: OpenFOAM usually provides info about the reason it is not working. Please add it to the post, it helps the others to give you the solution to your problem.... And not a guess like I just have done.
Best regards,
Frederic
QLintulsa June 17, 2014 17:39
error in the nonuniform inlet
Originally Posted by fcollonv (Post 388051)
Hi Prash,
inlet
    type fixedValue;
    100(
    (0 0 0)
Best regards,
Frederic
I have used this method to use experiment data as inlet, but it doesn't work for me, does anyone use this method? thanks
