Adding Temperature field to IcoFoam
I followed this tutorial on the wiki page http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam I ran my_icoFoam and it gave me this message FOAM Warning : From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s) in file /home/ramesh/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 252 Reading "/home/ramesh/OpenFOAM/ramesh-1.5/run/my_icoFoam_cavity/0/T::movingWall" from line 25 to line 26 expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. --> FOAM Warning : From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s) in file /home/ramesh/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 252 Reading "/home/ramesh/OpenFOAM/ramesh-1.5/run/my_icoFoam_cavity/0/T::fixedWalls" from line 31 to line 32 expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0 max: 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.96338e-06, No Iterations 8 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for p, Initial residual = 1, Final residual = 7.55402e-07, No Iterations 35 time step continuity errors : sum local = 5.03809e-09, global = 1.94884e-19, cumulative = 1.94884e-19 DICPCG: Solving for p, Initial residual = 0.523591, Final residual = 9.72352e-07, No Iterations 34 time step continuity errors : sum local = 1.07766e-08, global = 4.49324e-19, cumulative = 6.44208e-19 gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type fixedvalue) on patch movingWall of field T in file "/home/ramesh/OpenFOAM/ramesh-1.5/run/my_icoFoam_cavity/0/T" You are probably trying to solve for a field with a generic boundary condition. From function genericFvPatchField<Type>::gradientInternalCoeffs( ) const in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 692. FOAM exiting any help would be appreciated. Thanks Ramesh |
Yes, I guess my supervisor will also push me to do similar works in the next step :o...
Thanks!. I have fixed the bug...... Ramesh |
how did you fix the bug mate? I am also having similar bug when i tried a different boundary condition say parabolicVelocityInlet.
Can you please be more specific?. Share your code so that I can have a look
The tutorial listings lacked the keyword "uniform" from the definition of the value in the boundary conditions.
The wiki's been edited to fix this - but the information is contained in the "warning" messages that were posted. -Mike |
Hi friends,
I am facing sm pbm while compiling my own icoFOAM solver using wmake command..I m getting following pbm javed@javed:~/OpenFOAM-RUN/OpenFOAM-1.6/applications/solvers/incompressible/icoFoam_temp$ wmake make: *** No rule to make target `icoFoam.dep', needed by `Make/linuxGccDPOpt/dependencies'. Stop. Please help me out. |
Always use wclean before wmake. Or make sure there is no .dep file while doing wmake.
Nishant |
Thanks Nishant for the quick reply..
Now after doing all the changes as per given in http://openfoamwiki.net/index.php/How_to_add_temperature_to_icoFoam, I am not able to run it as follow...plz help friends...As i m running javed@javed:~/OpenFOAM-RUN/OpenFOAM-1.6/tutorials/incompressible/icoFoam/mycavity$ myicoFoam Case : /home/javed/OpenFOAM-RUN/OpenFOAM-1.6/tutorials/incompressible/icoFoam/mycavity nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 // using new solver syntax: p { solver PCG; preconditioner { type DIC; } minIter 0; maxIter 2000; tolerance 1e-06; relTol 0; } // using new solver syntax: T { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } // using new solver syntax: U { solver PBiCG; preconditioner { type DILU; } minIter 0; maxIter 500; tolerance 1e-05; relTol 0; } Reading transportProperties Reading field p Reading field U Reading field T Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0 max: 0 keyword preconditioner is undefined in dictionary "::preconditioner" file: ::preconditioner from line 47 to line 47. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 388. FOAM exiting Plz help... Thanks |
As far as I can see, there is some mismatch in the format of the other fields and Temperature field. Change that and see if it works.
But If you dont get it right after that, then post the line 47 (lets make it line: 40-50) of the asked file here. regards, Nishant |
Hi Javed,
Hmm, I think system/fvSolution should look something like this: Code:
p { solver PCG; preconditioner DIC; minIter 0; maxIter 2000; tolerance 1e-06; relTol 0; } This sort of presenting the fvSolution will solve the problem |
I need to add energy equation to simpleFoam. There are some threads about it but they all used laminar model. Is there any model for turbulent, steady, incompressible (official or non) flow solver? Can you give me some hints? Kind regards Umut |
buoyantBoussinesqSimpleFoam
Hi, Ramesh
I have also getting the following error while adding temperature filed to my icoFoam solver. Actually I am trying to use icoFoam solver for lagrangian particle tracking algorithm. when i run my model without adding temperature field, it works but when i add temperature filed, it doesn`t work usman@hyazinth:~/OpenFOAM/usman-2.3.x/applications/solvers/colloidalFoam_T> wmake Making dependency list for source file colloidalFoam.C SOURCE=colloidalFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/lagrangian/colloidalParticle/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/lagrangian/basic/lnInclude -I../colloidalParticle/lnInclude -IlnInclude -I. -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/colloidalFoam.o colloidalFoam.C: In function ‘int main(int, char**)’: colloidalFoam.C:110:9: error: no matching function for call to ‘Foam::fvMatrix<double>::fvMatrix(Foam::tmp<Foam:: fvMatrix<Foam::Vector<double> > >)’ colloidalFoam.C:110:9: note: candidates are: /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, Foam::Istream&) [with Type = double] /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:418:1: note: candidate expects 2 arguments, 1 provided /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::tmp<Foam::fvMatrix<Type> >&) [with Type = double] /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:361:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::tmp<Foam::fvMatrix<double> >&’ /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::fvMatrix<Type>&) [with Type = double] /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:330:1: note: no known conversion for argument 1 from ‘Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ to ‘const Foam::fvMatrix<double>&’ /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = double] /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMatrix.C:273:1: note: candidate expects 2 arguments, 1 provided /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’ [-Wunused-variable] /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’ [-Wunused-variable] /nfs/opt/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’ [-Wunused-variable] make: *** [Make/linux64GccDPOpt/colloidalFoam.o] Error 1 |
