[Sponsors] | |||||
#21 |
Arne Stahlmann
Rep Power: 6 ![]() |
Hi camoesas (and others),
may I ask if you found a solution for it? I'm having similar trouble right now, so maybe you have a hint for me: Use sampled data from previous run as boundary condition for new setup Thanks, Arne |
#22 |
HI Arne,
I made it this way: > foamToSurface file.ext This Utility writes geometry information about your cells at the boundary. For 'ext' use one of 13 possible formats. (I forget which one I used) Then I have read the points in matlab and calculated the corresponding values. these I have copied in my boundary file. Instead of matlab of course you can use anything else. But you have to deliver the values for the center of the cells not the nodes... good luck
OF - 2.0.0 |
| Tags |
| dtris2 |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
| Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
| Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
| DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
| user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
