-   -   OpenFOAM v1.6 & OpenMPI & functionObjects (http://www.cfd-online.com/Forums/openfoam-solving/67167-openfoam-v1-6-openmpi-functionobjects.html)
bruce August 6, 2009 03:58
Hello All,
I run a case parallel with "functionObjects" in controlDict in OpenFOAM Version 1.6.
I use pre compiled OpenFOAM1.6 & openmpi versions.
- case runs fine in single processor with "functionObjects"
- case runs fine in parallel multiple processor without "functionObjects"
The problem is case do not run with "functionObjects" in parallel !!! So i get an run time error.
Here is the content of the functionObjects i use in controlDict file,
functions
fieldMinMax
type fieldMinMax;
functionObjectLibs ("libfieldFunctionObjects.so");
log yes;
outputControl timeStep;
outputInterval 1;
mode magnitude;
fields
U
p
Here is an error output from simpleFoam solver,
Time = 1
smoothSolver: Solving for Ux, Initial residual = 0.000858153, Final residual = 4.80409e-05, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.00247583, Final residual = 0.000145901, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.00376188, Final residual = 0.000214772, No Iterations 4
GAMG: Solving for p, Initial residual = 0.140115, Final residual = 0.0044083, No Iterations 2
time step continuity errors : sum local = 0.0024423, global = -1.95703e-05, cumulative = -1.95703e-05
smoothSolver: Solving for omega, Initial residual = 0.000519947, Final residual = 2.3265e-05, No Iterations 3
smoothSolver: Solving for k, Initial residual = 0.00221736, Final residual = 9.98441e-05, No Iterations 3
ExecutionTime = 46.25 s ClockTime = 47 s
[cfd4:17702] *** An error occurred in MPI_Recv
[cfd4:17702] *** on communicator MPI_COMM_WORLD
[cfd4:17702] *** MPI_ERR_TRUNCATE: message truncated
[cfd4:17702] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
mpirun has exited due to process rank 0 with PID 17702 on
node cfd4 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
For information, MPI_BUFFER_SIZE=20000000
So it seems OpenMPI crashes calling function{} !?
I am glad to provide necessary information to debug the problem.
Thanks
mattijs August 7, 2009 13:15
Can you report a bug in the OpenFOAM-bugs section?
