-   -   timeVaryingMappedFixedValue boundary condition in parallel (http://www.cfd-online.com/Forums/openfoam-solving/67579-timevaryingmappedfixedvalue-boundary-condition-parallel.html)
sega August 19, 2009 12:54
Hello World.
I was not able to decompose a case which used the timeVaryingMappedFixedValue boundary condition!
Does anybody know if it's possible to use this boundary condition in parallel?
sega
henrik August 19, 2009 13:15
Dear Sebastian,
it should work out of the box. There will be triangulated surfaces on every processor. But that's not something to worry about.
Henrik
sega August 20, 2009 04:06
Thank you Henrik.
But I was not able to do so.
I got a segmentation fault when running the decomposer.
Is there some trick involved?
sega August 25, 2009 10:30
I want to get back to my problem with decomposing a case with timeVaryingMappedFixedValue boundary conditions.
I got this message when running decomposePar
sega@deepblue:~/OpenFOAM/sega-1.5/run/arcSmall0$ decomposePar
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  1.5                                  |
|  \\  /    A nd          | Web:      http://www.OpenFOAM.org              |
|    \\/    M anipulation  |                                                |
Exec  : decomposePar
Date  : Aug 25 2009
Time  : 16:22:49
Host  : deepblue
PID    : 4859
Case  : /home/sega/OpenFOAM/sega-1.5/run/arcSmall0
nProcs : 1
Create time
Time = 0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod simple
Finished decomposition in 0.03 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Calculating processor boundary addressing
Distributing points to processors
Constructing processor meshes
Processor 0
    Number of cells = 4000
    Number of faces shared with processor 1 = 200
    Number of processor patches = 1
    Number of processor faces = 200
    Number of boundary faces = 1400
Processor 1
    Number of faces shared with processor 0 = 200
Max number of processor patches = 1
Max number of faces between processors = 200
#0  Foam::error::printStack(Foam::Ostream&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigSegv::sigSegvHandler(int) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  ?? in "/lib/libc.so.6"
#3  vbedg(double, double, int, double*, int, int*, int*, int*, int*, int*, int*) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so"
#4  dtris2(int, double*, int*, int*, int*) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so"
#5  Foam::triSurfaceTools::delaunay2D(Foam::List<Foam::Vector2D<double> > const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so"
#6  Foam::timeVaryingMappedFixedValueFvPatchField<double>::readSamplePoints() in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#7  Foam::timeVaryingMappedFixedValueFvPatchField<double>::checkTable() in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#8  Foam::timeVaryingMappedFixedValueFvPatchField<double>::updateCoeffs() in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#9  Foam::timeVaryingMappedFixedValueFvPatchField<double>::timeVaryingMappedFixedValueFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#10  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::timeVaryingMappedFixedValueFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#11  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#12  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#13  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#14  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#15  void Foam::readFields<domainDecomposition, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >(domainDecomposition const&, Foam::IOobjectList const&, Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#16  main in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#17  __libc_start_main in "/lib/libc.so.6"
#18  Foam::fvMesh::readUpdate() in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
Segmentation fault
I can't tell whats wrong in this case.
Please feel free to have a look at the case itself: http://therealsega.th.funpic.de/open...cSmall0.tar.gz
If you are talking about triangulation ... Do I have to switch one anything for it to work?!
All I was doing was collecting the necessary data for the boundary condition and setting them like this:
    f0
        type            timeVaryingMappedFixedValue;
        setAverage    off;
So, where may be the fault?!
mattijs August 27, 2009 17:29
icoFoam does not run with your point set either. Seems your pointset makes the triangulation routine fall over. Set the debug flag timeVaryingMappedFixedValue to 1 in the etc/controlDict. It will output a triangulation.stl which you can load into paraview for checking.
sega August 28, 2009 03:17
I could narrow the problem down and have taken my questions concerning it to an other thread. Have a look:
http://www.cfd-online.com/Forums/ope...ixedvalue.html
(or maybe http://www.cfd-online.com/Forums/ope...tal-error.html)
Hisham June 25, 2012 09:51
Hello Sebastian
I have a Seg Fault (fp) error in running a case in parallel that has a timeVarryingMapped BC that is divided. So I think it may be the cause of the error ... so how is your status on the topic???
Best regards
Hisham
