Don't know if this is a bug or
if I am just plain dumb (probably the latter) but can somebody please help:
The offending piece of code I am trying to create in a modified turbulence model reads void kEpsilonSwirl::updateSwirlSource() { Info << "Here 0" << endl; const volVectorField& rP0 = mesh_.C()-axisPoint_; Info << "Here 1" << endl; const volVectorField& rProj0 = (rP0 & axisDir_)*axisDir_/magSqr(axisDir_); Info << "Here 2 " << endl; ..... As you see I have instrumented it to see where things go wrong: the code compiles OK but when I run it I get the following: .... Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilonSwirl kEpsilonSwirlCoeffs { Cmu 0.09; C1 1.44; C2 1.92; alphaEps 0.76923; axisDir axisDir [ 0 1 0 0 0 0 0 ] ( 1 0 0 ); axisPoint axisPoint [ 0 1 0 0 0 0 0 ] ( 0 0 0 ); sigmaEps 1.3; } Starting time loop Time = 0.01 Courant Number mean: 0.0176233 max: 0.39971 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.55993e-10, No Iterations 3 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.37146e-06, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 3.3967e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0558327, No Iterations 2 time step continuity errors : sum local = 1.42616e-05, global = -6.28859e-08, cumulative = -6.28859e-08 DICPCG: Solving for p, Initial residual = 0.0989443, Final residual = 7.7364e-07, No Iterations 57 time step continuity errors : sum local = 3.95132e-10, global = -1.68916e-12, cumulative = -6.28876e-08 Here 0 Here 1 terminate called after throwing an instance of 'std::length_error' what(): basic_string::_S_create I've tried a number of different options, which either don't compile or don't run. Help!! Gerrie Thiart |
Your code is wrong: you are taking a reference to a temporary. Do:
volVectorField rP0 = mesh_.C()-axisPoint_; volVectorField rProj0 = (rP0 & xisDir_)*axisDir_/magSqr(axisDir_); You cannot take a reference to a result of field algebra - it will be a new field. Enjoy, Hrv |
Great! Thanks,
from a bedraggled C++ wannabee.
:-] Gerrie Thiart |
