Error in turbulentHeatFluxTemperatureFvPatchScalarField v1.6 |
September 16, 2009, 08:06 |
I noticed an error in turbulentHeatFluxTemperatureFvPatchScalarField class for temperature gradient calculation:
00146 void turbulentHeatFluxTemperatureFvPatchScalarField::updateCoeffs() 00147 { 00148 if (updated()) 00149 { 00150 return; 00151 } 00152 00153 const scalarField& alphaEffp = 00154 patch().lookupPatchField<volScalarField, scalar>(alphaEffName_); 00155 00156 const scalarField& Cpp = 00157 patch().lookupPatchField<volScalarField, scalar>(CpName_); 00158 00159 gradient() = q_/(Cpp*alphaEffp); 00160 00161 fixedGradientFvPatchScalarField::updateCoeffs(); 00162 } q = lambda * grad (T) = alpha * rho * Cp * grad (T) where lambda - thermal conductivity alpha - thermal diffusivity Cp - cpecific heat capacity rho - density Thus temperature gradient should be grad (T) = q / (alpha * rho * Cp) Please correct me if I'm wrong!
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at Last edited by makaveli_lcf; September 17, 2009 at 08:47. |
September 17, 2009, 02:36 |
#2 | |
Mark Olesen
Rep Power: 40 |
They are formulated somewhat differently and the incompressible formulation will obviously not have rho in it. |
September 17, 2009, 03:32 |
Mark,
I'm speaking about incompressible namespace. In any case, if not include density in heat flux calculations, left-hand and right-hand dimensions in that relationship will not meet! That is what I mean in details: Code:
00053 class turbulentHeatFluxTemperatureFvPatchScalarField 00054 : 00055 public fixedGradientFvPatchScalarField 00056 { 00057 // Private data 00058 00059 //- Heat flux [W/m2] 00060 scalarField q_; 00061 00062 //- Name of effective thermal diffusivity field 00063 word alphaEffName_; 00064 00065 //- Name of specific heat capacity field 00066 word CpName_; 00067 [q] = W / m^2 = (J / s) / m^2 = (kg m^2 / s^3) / m^2 = kg / s^3 [lambda] = W / (m K)= (kg m^2 / s^3) / (m K) = kg m / (K s^3) [alpha = lambda / (rho Cp)] = m^2 / s [Cp] = J / (kg K) = (kg m^2 / s^2 ) / (kg K) = m^2 / (K s^2) [grad (T)] = K / m Thus q = lambda * grad (T) => [LHS] = W / m^2 equal to [RHS] = W / (m K) * K / m = W / m^2 But if we calculate grad (T) as q / (alpha Cp), then we get grad (T) = q / (alpha Cp) => [LHS] = K / m not equal to! [RHS] = kg / s^3 / (m^2 / s * m^2 / (K s^2)) = kg K / m^4 So we see that dimensions of the left-hand side (LHS) and the right-hand side (RHS) do not meet unless other than traditional units are used for thermal conductivity, thermal diffusivity, specific heat capacity etc. It is easy to check, that q = (alpha Cp rho ) grad (T) => grad (T) = q / (alpha Cp rho) gives correct result after dimensions analyzis.
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at Last edited by makaveli_lcf; September 17, 2009 at 08:48. |
September 17, 2009, 09:54 |
Yi Wang
Rep Power: 17 |
Not sure in incompressible solvers. But in compressible solvers, alphaEff and alpha defined in OF are not the same as the alpha [m^2/s] that we typically refer to.
They actually have already included rho in the definition. Basically in OpenFOAM: alpha = lambda/Cp ( not lambda/Cp/rho) You might want to check the thermoPhysicalModel to find it out. |
September 17, 2009, 10:28 |
Thank you, Yi!
Following your guidance I found in basicThermo_8H_source.html: Code:
00077 //- Laminar thermal diffusuvity [kg/m/s] 00078 volScalarField alpha_;
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
Forces in V1.6 | terrybarnaby | OpenFOAM Post-Processing | 72 | September 2, 2015 16:49 |
installing v1.6 and keeping v1.5 | Gavin | OpenFOAM | 9 | October 23, 2009 04:16 |
nutRoughWallFunction v1.6 | Schag | OpenFOAM | 2 | October 1, 2009 16:28 |
icoDyMFoam v1.6 | shyam | OpenFOAM Bugs | 1 | September 5, 2009 04:22 |
Postprocessing and uniformDensityHydrostaticPressure in v1.6 | Schag | OpenFOAM Bugs | 2 | July 28, 2009 13:41 |
