September 8, 2009, 04:58 |
Multi-Body Airfoil simulation problems
Hi Foamers,
I'm trying to simulate the flow around a 2D high lift configuration airfoil (slat - main - flap), Re=6x10^6, Ma=0.2, AoA = 12.2°, with simpleFoam, k-Omega SST turbulence. I tryied both high Re mesh type, so yPlusMin > 30, and Low Re mesh type, so yPlusMax < 1, as in OF 1.6 it's possible to switch off the wall-functions in SSt model. My boundary condition are: Far field: U - inletOutlet p - inletOutlet k - turbulentIntensityKineticEnergyInlet Omega - turbulentMixingLengthFrequencyInlet Walls with yPlus > 30 U - fixedValue (0 0 0) p - zeroGradient k - kqRWallFunction Omega - omegaWallFunction Walls with yPlus < 1 U - fixedValue (0 0 0) p - zeroGradient k - fixedValue 0 Omega - omegaWallFunction I used the standard best-practise to get the solution, so starting with upwind schemes at the beginning and then 2° order Gamma schemes, playing with the relaxation factors to make it converge, and I get a stable solution. My fvSchemes and fvSolution are attached. The results are like this: U P k cp The cp values are completely incorrect, as the reference solution for this case has a negative peak of around -4 near the main, and a cp of about -2 / -2.5 on the main upper surface. Does anyone have some idea to get better results? I'm struggling on it from weeks... Have a nice day! |
September 11, 2009, 10:18 |
Luca Gasparini
Rep Power: 17 |
Dear Ivan,
I couldn't see the Cp plot so don't really know how far you are, still I couldn't find anything obviously wrong in your fvSchemes and fvSolution files. If you agree, I would be interested in trying computing this case (I was looking for multi -airfoil test cases) and share with you the results if you could give me the geometry (best would be your own grid and the full OF case, but would be nice to have the airfoil coordinates so that I could optionally generate a new mesh as well). To be fair, I would ask you a reference to the experimental results only after having done the computations.. Ciao, Luca |
September 17, 2009, 05:38 |
Age Nammensma
Rep Power: 17 |
Your pressure is ~3 times atmospheric...
problems of turbo simulation in CFX-10 | Qiang | CFX | 0 | September 11, 2006 23:19 |
Compressible transonic airfoil RAE2822 simulation | Stefano | Siemens | 9 | June 21, 2006 10:47 |
Biphasic simulation (GVF 80%) - Overflow problems | Robbe | CFX | 0 | February 21, 2006 10:22 |
2D Simulation Airfoil Aspect Ratio | Kramer | CFX | 7 | February 6, 2006 13:35 |
Problems with SUPG body force term | FEM question | Main CFD Forum | 0 | January 21, 2006 17:51 |
