-   -   InterDyMFoam with GGI (http://www.cfd-online.com/Forums/openfoam-solving/68375-interdymfoam-ggi.html)
sebastianweiper September 17, 2009 03:38
2 Attachment(s)
Hi Foamers,
I am trying to simulate a case with two fluids with a moving mehs. First i have looked at the interDyMFoam tutorials but these cases doesnīt fit to my Problem.
I take the tutorial case mixerGgi from icoDyMFoam and modify it for a simulation of 2 fluids. The Problem is that the Case doesnīt run.
So I modified the interDyMFoam Solver and delete everything that I get only the moving. This works fine.
But when I use the normal interDyMFoam solver i got a "Floiting point exception" and i donīt know where the Problem is.
Thank you for your Help
Sebastian
lord_kossity September 18, 2009 03:20
1 Attachment(s)
Hi Sebastian,
I had a look at your case and the reason for floating point exception is caused by the initial boundary conditions for k and epsilon.
On the ggi patch I changed their uniform value to sth. different than 0 and added entries for k and epsilon to fvSchemes and fvSolution. Case is running now, see attached file.
Best,
Andreas
sebastianweiper September 18, 2009 03:43
Thank you. This solved my Problem.
