September 17, 2009, 03:38 |
InterDyMFoam with GGI
Sebastian Weiper
Hi Foamers,
I am trying to simulate a case with two fluids with a moving mehs. First i have looked at the interDyMFoam tutorials but these cases doesn´t fit to my Problem. I take the tutorial case mixerGgi from icoDyMFoam and modify it for a simulation of 2 fluids. The Problem is that the Case doesn´t run. So I modified the interDyMFoam Solver and delete everything that I get only the moving. This works fine. But when I use the normal interDyMFoam solver i got a "Floiting point exception" and i don´t know where the Problem is. Thank you for your Help Sebastian |
September 18, 2009, 03:20 |
Andreas Dietz
Hi Sebastian,
I had a look at your case and the reason for floating point exception is caused by the initial boundary conditions for k and epsilon. On the ggi patch I changed their uniform value to sth. different than 0 and added entries for k and epsilon to fvSchemes and fvSolution. Case is running now, see attached file. Best, Andreas |
September 18, 2009, 03:43 |
Sebastian Weiper
Thank you. This solved my Problem.
Software: OpenFOAM 1.5-dev |
Performance of GGI case in parallel | hannes | OpenFOAM Running, Solving & CFD | 26 | August 3, 2011 03:07 |
GGI in OpenFOAM | hjasak | OpenFOAM Running, Solving & CFD | 59 | April 30, 2010 08:30 |
CFX GGI Interface Error (non-overlapping) | surge519 | CFX | 1 | August 3, 2009 18:54 |
Periodic GGI, How to | sponiar | OpenFOAM Running, Solving & CFD | 0 | May 26, 2009 03:50 |
GGI ERCOFTAC and general questions | david | OpenFOAM Running, Solving & CFD | 8 | August 25, 2008 09:22 |
