September 23, 2009, 05:27 |
yPlusRAS in OF 1.6.x - Low Re Models
Hi Foamers,
I've just noticed that in OF 1.6.x you can only use yPlusRAS if you have a wallFunction on nut field. I'm trying to apply a low Re calculation with simpleFoam, SST model, so I've changed thewall bc on k to fixedValue and on nut to calculated, but in this cases yPlusRAS does not work. I've circumvented the problem adding a false wallfunction on nut just when calculating yPlusRAS, but is not so a clear approach. Has someone coded a yPlusRAS also for LowRE models? Best regards, Ivan |
Implementing low Re number k-e models in Fluent. | kiran | FLUENT | 1 | July 3, 2017 17:04 |
low reynolds number models in Fluent | doug | Main CFD Forum | 6 | August 4, 2012 14:39 |
low Re number k-epslon models | Hossam | FLUENT | 1 | July 13, 2008 05:00 |
Turbulence Models for very low Reynolds Numbers | Sudhi | CFX | 1 | March 2, 2007 18:03 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
