engine-mesh, layer removal?
Old   October 19, 2009, 10:46
Default engine-mesh, layer removal?
anonymous
koreapostdoc is on a distinguished road
I made a case to run with dieselEngineFoam(kivaTest+aachenBomb). Everything is ok but mesh. I started the simulation at BDC. At TDC I have a deformed mesh with the same number of cells. There is no layer removal.
-would you please guide me to set the case correctly.
-should I change the code or do any pre-processing?
Thank you
koreapostdoc is offline   Reply With Quote
Old   October 20, 2009, 03:22
dipling is on a distinguished road
u have to implement the engineTopoChangerMesh class
engineTopoChangerMesh layerAR; instead of
engineMesh layered;
in the engineGeometry file. Define delta and offset and min/maxlayerthickness for your calculation. That should be almost all.
If u have more questions please search for papers from Tommaso Lucchini.
regards
dipling is offline   Reply With Quote
Dynamic Mesh with Boundary Layer Marcell FLUENT 0 March 11, 2009 08:40
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Need help to mesh Wankel engine Sam Main CFD Forum 3 October 4, 2007 20:33
[Technical] 3D mesh with boundary layer fra76 OpenFOAM Meshing & Mesh Conversion 0 May 21, 2006 03:32
boundary layer mesh merac FLUENT 1 June 19, 2001 11:45
