April 26, 2018, 14:40 |
No heat transfer with fixedGradient/groovyBC
Rep Power: 8 |
Hi all
I'm trying to replicate the results of this paper: https://www.sciencedirect.com/scienc...60132316300208 It uses a slightly adapted solver (https://link.springer.com/article/10...546-008-9325-7) which I believe I've implemented correctly into OpenFOAM. Here's a simple schematic of the 2D problem: I've tried using groovyBC to set a gradient and just using fixedGradient to get heat transfer across the red patch. Here's my 0/T file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1612+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { floor { type fixedValue; value uniform 300; } hotWall { type groovyBC; value uniform 300; valueExpression "300"; gradientExpression "gradT"; fractionExpression "0"; variables ( "heatFlux=37;" "rho=1.2;" "cp=1.0;" "nutemp=1.0e-5;" "pr=0.9;" "kappa=nutemp/pr;" "gradT=heatFlux/((kappa+alphat)*rho*cp);" ); // evaluateDuringConstruction true; } ceiling { type inletOutlet; inletValue uniform 300; value uniform 300; } fixedWallsX1 { type symmetry; } fixedWallsX2 { type inletOutlet; inletValue uniform 300; value uniform 300; } defaultFaces { type empty; } } // ************************************************************************* // Here are the steps I have taken: I thought perhaps I'd implemented the T equation incorrectly, so I tried using setFields to create a high temperature area in the middle of the domain. This behaved as normally, causing vertical perturbations and the high temperature diffused. I also thought perhaps the BC itself wasn't working. I modified the hotRoom tutorial to have the same groovyBC and ran it with my custom solver, but the effects of the temperature gradient are quite obvious. I thought perhaps my mesh was the issue, as that's the main difference between the modified hotRoom and this case. Here is my blockMesh: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1000; vertices ( (0 0 0)//0 (10 0 0)//1 (10 1 0)//2 (0 1 0)//3 (0 0 3)//4 (10 0 3)//5 (10 1 3)//6 (0 1 3)//7 ); blocks ( hex (0 1 2 3 4 5 6 7) (37 1 150) simpleGrading (1 1 1436) ); edges ( ); boundary ( floor { type wall; faces ( (0 3 2 1) ); } ceiling { type patch; faces ( (4 5 6 7) ); } fixedWallsX1 { type symmetry; faces ( (0 4 7 3) ); } fixedWallsX2 { type patch; faces ( (1 5 6 2) ); } ); mergePatchPairs ( ); // ************************************************************************* // I've tried applying the BC to the ceiling and the right hand outlet and when I execute, the case rapidly explodes, so it's clearly doing something. I thought perhaps the issue was to do with the hotWall patch not working correctly, so I just applied the groovyBC to the floor instead and nothing happens. Here are my fvSchemes and fvSolutions: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-3; relTol 0; } pFinal { $p; relTol 0; tolerance 1e-3; } U { solver PBiCGStab; preconditioner DILU; tolerance 1e-3; relTol 0; } UFinal { $U; relTol 0; tolerance 1e-3; } "(T|k|epsilon|R)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-3; relTol 0; } "(T|k|epsilon|R)Final" { $U; relTol 0; tolerance 1e-3; } } PIMPLE { momentumPredictor yes; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { U { tolerance 1e-3; relTol 0; } p { tolerance 1e-3; relTol 0; } T { tolerance 1e-3; relTol 0; } k { tolerance 1e-3; relTol 0; } epsilon { tolerance 1e-3; relTol 0; } R { tolerance 1e-3; relTol 0; } } } relaxationFactors { equations { "(U|T|k|epsilon|R)" 1; "(U|T|k|epsilon|R)Final" 1; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss upwind; div(phi,T) Gauss linear; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; laplacian(nuEff,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; laplacian(alphaEff,T) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default uncorrected; } // ************************************************************************* // Does anyone have any experience with this? Can provide any other information needed Cheers |
April 27, 2018, 13:04 |
Rep Power: 12 |
I don't know exactly what's going wrong, but if it were me I would not use a special patch for the hot wall boundary condition and I would just use a conditional statement, i.e. x < 0.1, etc... to define which portion of the wall gets the flux condition. Then you eliminate the extra step of defining multiple blocks or special patches, etc... just a thought.
Flow around heatsink with heat transfer | S Mughal | FLUENT | 0 | April 13, 2018 13:06 |
Heat transfer using all modes | bhups45 | FLUENT | 0 | June 19, 2016 07:02 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
