mapping of pressure field (simplefoam to cavitatingFoam) |
February 14, 2011, 09:58 |
Rep Power: 16 |
Hello to all,
I would like to map the pressure field of simpleFoam to cavitatingFoam. There is difference in pressue field of simpleFoam(it is in m2/s2 units) and cavitatingFoam( it is in kg/m/s2). There is difference between them by factor of density of fluid i am using. For that i have a file. I just found it in internet. Could any one tell me how to use it??? Thanks in advance. Last edited by siddharameshwara; February 17, 2011 at 05:17. |
February 15, 2011, 02:55 |
Matthias Voß
Rep Power: 20 |
how can anybody know what you found "in the internet".
What kind of packages/data do you get after unpacking the file? |
February 15, 2011, 03:05 |
Rep Power: 16 |
I am new to this openFoam. So i didnt posted in a right way. It contains Make directory with 'files and options' files in it. and also convertPhi.C file. So i dont know how i can use it so that i can map(pressure field) from simpleFoam result to cavitatingFoam. Or...is there any way to map the fields?? kindly suggest me. Thanks |
February 15, 2011, 03:14 |
Matthias Voß
Rep Power: 20 |
try to run wclean and a wmake in that directory. that will give you a library convertingPhi.lo which you can run from within your cavitatingFoam dir after maping your simpleFoam results.
Why don´t you just copy the 0/p-U-... files (convert them properly) from simpleFoam and run cavitatingFoam? But mapping is also fine.... neewbie |
February 15, 2011, 04:47 |
Rep Power: 16 |
Thank you very much for the quick response. I tried the way you told me. I tried to make dynamic linking by typing the command wmake libso. It displayed the following message. 'libNULL.so' is up to date So now if i want to use it how i can use???...how this could be used to map the results i am sorry if this question is silly. Thanks in advance.. |
February 15, 2011, 04:49 |
Matthias Voß
Rep Power: 20 |
why wmake libso?
Can you post a download? |
February 15, 2011, 05:07 |
Rep Power: 16 |
When i looked in my documents i have found wmake libso would be best one. So, that it will have dynamic linking. I think it doesnt matter if it is static or dynamic link. Correct me if i am wrong!! You can find in my attachments convertPhi.C file I cant upload file and options. I have some problem. In the Make--> file its written convertPhi.C EXE = $(FOAM_APPBIN)/convertPhi and in make--> options its written EXE_INC = \ -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = \ -lfiniteVolume Last edited by siddharameshwara; February 17, 2011 at 05:11. |
February 15, 2011, 05:16 |
Matthias Voß
Rep Power: 20 |
change
convertPhi.C EXE = $(FOAM_APPBIN)/convertPhi to myconvertPhi.C EXE = $(FOAM_USER_RAPPBIN)/myconvertPhi change the .C file to myconvertPhi.C wclean wmake (not wmake libso) run the tool in the copied file-structure of the simpleFoam run by typing myconvertPhi Make sure $FOAM_USER_APPBIN is set properly, check with echo $FOAM_USER_APPBIN. neewbie |
February 15, 2011, 05:39 |
#9 |
Rep Power: 16 |
myconvertPhi Hi, I didnt understand the above statement. Firstly, i will get the solution by typing the command simpleFoam in my directory where i am solving problem. So, when i have to type this command myconvertPhi after getting the solution of simpleFoam or what?? i cant type the command myconvertPhi and simpleFoam at a time. Secondly should i copy the files that i have send you in the directory where i have ia m running simpleFoam Thirdly, How after running the simulation i can map it. Please clear this. i am sorry if i am roubling you. Thnaks |
February 15, 2011, 05:52 |
#10 | |||
Matthias Voß
Rep Power: 20 |
if you succeed then you should be able to type "myco+[TAB]" and your system will auto-complete the rest for you; as the autofilling is working your system knows where to search for "myconvertPhi"($FOAM_USER_APPBIN) and the tool can at least be executed 2.create a case and run simpleFOAM 3.run myconvertPhi there after the simpleFOAM finished 4. map to your cavitatingFOAM directory Quote:
February 15, 2011, 06:03 |
#11 |
Rep Power: 16 |
Thank you so much for the detail description. I will try it out the steps said by you. |
February 15, 2011, 08:21 |
#12 |
Rep Power: 16 |
I tried the steps said by you. But i am getting one error. I.e. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6.x Exec : myconvertPhi Date : Feb 15 2011 Time : 14:12:37 Host : rbgv119x PID : 4674 Case : /appl/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/fields/fvPatchFields/derived/myconvertPhi nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // --> FOAM FATAL ERROR: Missing reference density From function myconvertPhi in file myconvertPhi.C at line 43. FOAM exiting So where should i give this reference density??. in my case for simpleFoam solver no where i mentioned the density. I mentioned only kinematic viscocity in constant/transportProperties. So where can i give reference velocity or is there any other way???...Fluid is desel. Thanks inadvance. |
February 15, 2011, 08:46 |
#13 |
Matthias Voß
Rep Power: 20 |
first of all: it´s not good idea to put stuff in /appl/OpenFOAM/OpenFOAM-1.6.x/src/~ ... put your personal stuff beside the OF installation but that´s also a matter of taste.
rhoRef is a parameter for myconvertPhi Code:
if (!args.options().found("rhoRef")) { FatalErrorIn(args.executable()) << "Missing reference density" << endl; FatalError.exit(); } argc=Number of Arguments agrv=Argument so try smth. like myconvertPhi 1000 1000 being your rhoRef. Last edited by mvoss; February 16, 2011 at 03:24. |
February 15, 2011, 08:56 |
#14 |
Rep Power: 16 |
Hey,
Thank you so much. It worked out. I looked at my rhop new file everything is fine the values and all......wow...thanks a lot for all your messages. Have a g8 day!!! |
February 15, 2011, 08:59 |
#15 |
Matthias Voß
Rep Power: 20 |
u r welcome...
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
About Pressure Field with Cyclic Boundary Conditio | Jiaying Xu | Siemens | 2 | October 4, 2001 09:11 |
Using SIMPLE | david | Main CFD Forum | 5 | July 21, 1999 02:38 |
