Motorbike Tutorial
Hello everyone.
I'm a new member so I apologise for my ignorance. I've been working through the tutorials and decided to attempt the motobike tutorial. I manage to generate the mesh using blockmesh, snappyHexMesh. I still am unable to see the bike in paraFoam even after searching through the various threads. Someone mentioned reduce the xmin and ymax but I wasnt able to locate these options. Thoughts? Should I continue to suffer for a right of passage? It appears that this tutorial contains boundary conditions so I assumed I could run icoFoam or simpleFoam to obtain a solution. Is this correct. In attemp to run icoFoam and simpleFoam is closes by saying the following: Create time Create mesh for time = 3 Reading transportProperties Reading field p --> FOAM FATAL IO ERROR: cannot open file file: /home/adam/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/simpleFoam/motorBike/3/p at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 62. FOAM exiting I looked at the "3" folder which I believe is the final mesh folder and was not able to locate "p at line 0" Thanks everyone for the help. |
