-   -   doubt in representation the transpose of the velocity gradient (http://www.cfd-online.com/Forums/openfoam-solving/70300-doubt-representation-transpose-velocity-gradient.html)
titio November 19, 2009 15:11
Hi Foamers,
I have a problem where I have to use the gradient of the velocity and its transpose. To calculate the gradient of the velocity I can do it using the expression:
DU=fvc::grad(U);
However, the expression DUT=fvc::grad(U).T(); does not work. What I am doing is write DUT=DU.T();. Is this equivalent to the expression that I am writing. I believe it is as DUT as an variable will inherit all the characteristics of the variable DU. Both were defined as tensor fields initialized in the createFields.H file
If I am doing something, or there is a better way, please somebody tell how I can do this correctly.
Regards,
António Martins
