Home > Forums > OpenFOAM Running, Solving & CFD
pisoFoam Error
Old   November 20, 2009, 11:03
Default pisoFoam Error
sErik is on a distinguished road
Hej all,
I recieve this error when I execute pisoFoam:
__________________________________________________ ____________________
Calculating averages
Time = 0.00142
Courant Number mean: 3.72507e+52 max: 1.36418e+54
DILUPBiCG: Solving for Ux, Initial residual = 0.555198, Final residual = 1.81207e-06, No Iterations 35
DILUPBiCG: Solving for Uy, Initial residual = 0.882337, Final residual = 2.82071e-06, No Iterations 36
DILUPBiCG: Solving for Uz, Initial residual = 0.959453, Final residual = 2.3849e-06, No Iterations 29
DICPCG: Solving for p, Initial residual = 0.685706, Final residual = 0.0341773, No Iterations 70
time step continuity errors : sum local = 2.65701e+50, global = 1.48284e+49, cumulative = 1.38529e+49
DICPCG: Solving for p, Initial residual = 0.684507, Final residual = 9.50829e-07, No Iterations 171
time step continuity errors : sum local = 2.06627e+46, global = -1.52172e+44, cumulative = 1.38528e+49
DILUPBiCG: Solving for k, Initial residual = 0.88271, Final residual = 7.51988e-06, No Iterations 6
bounding k, min: -3.72039e+117 max: 7.6031e+117 average: 2.9493e+116
ExecutionTime = 164.59 s ClockTime = 165 s
Time = 0.00143
Courant Number mean: 8.88307e+51 max: 2.84151e+53
DILUPBiCG: Solving for Ux, Initial residual = 0.856534, Final residual = 7.94225e-06, No Iterations 39
DILUPBiCG: Solving for Uy, Initial residual = 0.826641, Final residual = 9.82446e-06, No Iterations 37
DILUPBiCG: Solving for Uz, Initial residual = 0.6356, Final residual = 6.89001e-06, No Iterations 35
DICPCG: Solving for p, Initial residual = 0.702043, Final residual = 0.0343882, No Iterations 78
time step continuity errors : sum local = 6.28092e+51, global = -2.13804e+49, cumulative = -7.5276e+48
DICPCG: Solving for p, Initial residual = 0.778709, Final residual = 8.64955e-07, No Iterations 171
time step continuity errors : sum local = 5.07704e+47, global = -7.17519e+44, cumulative = -7.52832e+48
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::incompressible::LESModels:neEqEddy::correc t(Foam::tmp<Foam::GeometricField<Foam::Tensor<doub le>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleLESModels.so"
#6 Foam::incompressible::LESModel::correct() in "/opt/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleLESModels.so"
#7 main in "/opt/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/pisoFoam"
#8 __libc_start_main in "/lib/libc.so.6"
#9 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Gleitkomma-Ausnahme
It's running for a while and then it crashes.
Could it be, that my Courant Number is much to hight? Or isn't there enough memory?
Have I nice weekend,
Erik
PS: I'll only be back on monday :-)
sErik is offline   Reply With Quote
Old   November 20, 2009, 15:23
akidess's Avatar
Anton Kidess
Yes, your simulations are diverging and the Courant number gets way out of hand. As usual, check your boundary and initial conditions, and then your numerical parameters. Time step looks like it's pretty small already, so I'm assuming that's not your problem.
Old   November 23, 2009, 08:49
Hi akidess,
thx for your help.
The courant number depends on the speed, the timestep and the cell size, right? But how can I improve the courant number? I have already tried even smaler time steps and also a smaler inital speed U, but with the same result.
What else could I do to make the calculation converging?
Old   November 23, 2009, 19:13
Alberto Passalacqua
Originally Posted by sErik View Post
Hi akidess,
thx for your help.
Info on CFL: http://en.wikipedia.org/wiki/Courant%E2%80%93Friedrichs%E2%80%93Lewy_condition
About your case, it would be useful to know some more details on the case and the numerical setup (fvSchemes, essentially).
Best,
Alberto Passalacqua
GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats.
Old   November 23, 2009, 20:53
akidess's Avatar
Anton Kidess
Changing the initial speed will not do a lot to fix your problem. A Courant number of ~e+52 is unphysical anyways.. As I said, check your boundary conditions and physical parameters, then come back here with more information on the problem (like Alberto said, fvSchemes would be good to look at).
Old   November 24, 2009, 04:33
Thank you very much, I really appreciate your help!
My case is about a pipe flow with a tube in the middle.
This is my fvSchemes file:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,T) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(kappaEff,T) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
I've just copied the file from the tutorial. I'm not so sure about the impact/meaning of every entry.
There are the initial conditions for U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
referenceField uniform (0.1 0 0);
value uniform (0.1 0 0);
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
frontAndBack
type fixedValue;
lowerWall
type fixedValue;
upperWall
type fixedValue;
Rohrelement_NASTRAN
type fixedValue;
And this one for p:
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
frontAndBack
type zeroGradient;
lowerWall
type zeroGradient;
upperWall
type zeroGradient;
Rohrelement_NASTRAN
type zeroGradient;
And here are the boundary conditions:
frontAndBack
type wall;
nFaces 266;
startFace 49933;
inlet
type patch;
nFaces 154;
startFace 50199;
outlet
type patch;
nFaces 367;
startFace 50353;
lowerWall
type wall;
nFaces 100;
startFace 50720;
upperWall
type wall;
nFaces 100;
startFace 50820;
Rohrelement_NASTRAN
type wall;
nFaces 3541;
startFace 50920;
To be honest, I'm not sure about all the effects of the "type-statements" like, "wall" or "patch" in the boundary conditions or "patch", "inletOutlet" for the initial conditions - or other statements for the cases. Wwhich/how many statements are there acually, with what kind of consequences? Is there a description or something like that, where I can figure out the effects on the solution?
Sorry for the long post.
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
