Foam error
Does anyone know why I would get this error?
Foam::error::printStack(Foam::Ostream&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::operator/(double const&, Foam::tmp<Foam::Field<double> > const&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::fvPatch::makeDeltaCoeffs(Foam::Field<double> &) const in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #6 Foam::surfaceInterpolation::makeDeltaCoeffs() const in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #7 Foam::surfaceInterpolation::deltaCoeffs() const in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #8 Foam::fvPatch::deltaCoeffs() const in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #9 Foam::basicSymmetryFvPatchField<Foam::Vector<doubl e> >::snGrad() const in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #10 Foam::fv::gaussGrad<Foam::Vector<double> >::correctBoundaryConditions(Foam::GeometricField< Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #11 Foam::fv::gaussGrad<Foam::Vector<double> >::grad(Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #12 Foam::tmp<Foam::GeometricField<Foam::outerProduct< Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so" #13 Foam::tmp<Foam::GeometricField<Foam::outerProduct< Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so" #14 Foam::incompressible::RASModels::kOmegaSST::kOmega SST(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so" #15 Foam::incompressible::RASModel::adddictionaryConst ructorToTable<Foam::incompressible::RASModels::kOm egaSST>::New(Foam::GeometricField<Foam::Vector<dou ble>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so" #16 Foam::incompressible::RASModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/work/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so" #17 main in "/home/work/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/simpleFoam" #18 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #19 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 I ran simpleFoam successfully on one geometry. When trying to run it on two very similar geometries I get this error. Thanks for the help. |
One other note, I get this error very early. The last line of output is "Selecting RAS turbulence model kOmegaSST". My guess is the error is there, probably where it calculates the coefficients, but I'm not sure why it worked before in such a similar geometry.
Another note, I took the omega and k files in directory zero from the motorBike tutorial as I have no idea how to generate those numbers. Any suggestions on how I might approach that if in fact that is the problem? Thanks |
